HobbiesHobby ForumHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Card Models > Radio Control & Other Propulsion Methods
Support our community and these ads go away.
Reply
Thread Tools Display Modes
Old 07-27-2006, 10:57 AM   #16 (permalink)
mbauer
Default
Hi Commando,
Just want to say thank you for the interest in my models! I hope you have fun experimenting with the bladders, or the CO2 cartridges!
Keep us posted with your results.
For anyone else that might be interested in the bladders, McMaster-Car "http://www.mcmaster.com" has tubing (Natural Latex Rubber Tubing), and some plastic tubing fittings that will work for nozzles (3/8"x3/8" coupler Part No. 5372k516).
I use the 1/4" ID x 3/16" Wall tubing with a Fiberglass nozzle to get the 11 oz of thrust for F104 and SR71.
For the fiberglass tube to make the extended nozzles, use fiberglass pushrod tubes made by Dave Brown Part No. PRDS-5400. These probably are in the LHS on a shelf or hanging on a peg.
The reason the above nozzle material is used, is because they will fit onto a can of computer keyboard cleaning/dusting air. Once the can empties, I cut the plastic assembley up and use the part as an adapter. Slide a basketball/football fill needle inside of it (Cut about 3/8" off of the needle end first) and use Gorrila Glue to glue them solid to make an adapter for bicycle pumps.
You can use any size/type of nozzle that you can get compressed air into the bladder with. I'm experimenting right now with a few different sized nozzles (1/4" I.D. to 1/2" I.D.). It takes 18#psi to expand the bladder on the thicker walled ones. I'm hoping 2-3 lbs of this will be available for thrust with bigger nozzles!
Anybody know of a good wind tunnel for sale? The small classroom size.
Best regards,
Mike Bauer
Best regards,
Mike Bauer
mbauer is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rod Powered Antique Oil Field Fred_M Scratchin' & Bashin' 32 01-20-2004 10:30 AM
New jet-powered locomotive digital_signal_ The Real Thing- USA 15 11-03-2002 06:51 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
Powered by vbWiki Pro 1.3 RC5. Copyright ©2006-2007, NuHit, LLC
