HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Card Models > Tips and Techniques
Reply
Thread Tools Display Modes
Old 04-16-2008, 03:38 PM   #31 (permalink)
blueeyedbear
Default
For a flat spray, I recommend a "matte fixative", such as the one made by Krylon. It is made for protecting artwork and I've never known it to cause any bleeding or discoloring. I use it as a "seal coat" under gloss Krylon, as well as for a flat finish.
I like the triple thick Krylon, but it's easy to over do and get globs and runs. Be careful with it. (And the fumes are toxic! That goes for all lacquer and oil-based sprays)
If you don't want to stink up the house, get a large cardboard box. Place it so the open side is to the front and use it for a spray booth. Close it while the spray gloss dries. (Also works well with an airbrush.)
Bob
blueeyedbear is offline   Reply With Quote
Old 04-16-2008, 08:32 PM   #32 (permalink)
CardStalker
CardStalker's Avatar
Default
Bob thanks for the great input. Tazman3, first off, the search function is a bit tricky and I too have problems with it. As to edge prepping, the clear coat does soak into the paper, the first couple of coats get sucked in and it is best if you spray the parts before cutting. Cutting after coating takes a little more effort, but I have found that if you attack the cut area first without getting into the paper you can make any adjustments to any area that you got off line on the next pass. Also it acts kind of like a guide as you finish cutting through. After the part is cut, when you edge prep the part it does not bleed in as much as with plain paper. If you look at this thread that I did on my Little Joe build: Little Joe Build, I show that I clear coated all the parts before cutting and edge prepping. Also I show how to remove the clear coat after the part is cut from any tabs that got coated to allow for gluing. Also if you check out my current build: Free Model #3 Hubble Sapce Telescope Build, and go to where I do the mirror, I show a technique on how to make the clear coat smoother.
CardStalker is offline   Reply With Quote
Old 07-01-2008, 10:22 PM   #33 (permalink)
oraclehara
Junior Member
Default
Quote:
Originally Posted by CardStalker View Post
Ok, here is a before and after shot. The one on the top is the as printed and the one on the bottom is Clear Coated. It took 4 light coats to get it to shine. You can't quite tell from the pic, but adding clear gloss makes the colors darker. Sorry for the glare but I wanted you to see the clear coat better.
Hi CardStalker,
I'm new to this papercraft hobby. I'm trying to build a car papercraft and there's one thing nice about a car is the glossy surface of its body works. I can see the effect of Krylon Triple Thick Crystal Clear Glaze giving a glossy finish to the paper. But i noticed that the glossy part is quite uneven. Is this caused by the paper and can I sand it using Tamiya's ultra fine sand paper?
Thanks.
oraclehara is online now   Reply With Quote
Old 07-02-2008, 07:50 AM   #34 (permalink)
CardStalker
Default
Hello oraclehara, welcome aboard. The wavy surface is from ther clear coat. If you apply it lightly many times it will not be as wavy. Yes you can sand it, but let it dry for at least a day. You will have to reapply the clear coat, but it will be smoother.
Old 07-02-2008, 08:53 AM   #35 (permalink)
oraclehara
Junior Member
Default
Thank you so much for clearing that out. I'm very new at this paper craft hobby. I'll post photos of my work when it's done.
Old 07-02-2008, 10:52 AM   #36 (permalink)
timhinds1@cox.net
timhinds1@cox.net's Avatar
Default
I have been clearcoating for years now. If you are loking for smooooooooth then print it on photo paper first. The shiny surface does not require a sealer coat and you will get a very nice finish. Just don't put it on too heavy. I use "Rustoleum Painter's Touch" with UV. It will give you a vinyl like texture and is flexible.
__________________
The older I get the more I did.
When life hands you a lemon, throw it back!
timhinds1@cox.net is offline   Reply With Quote
Old 07-02-2008, 08:46 PM   #37 (permalink)
oraclehara
Junior Member
Default
I went to the art shop yesterday to get the Krylon Triple Thick Crystal Clear Glaze and Matte Finish. But they ran out of stocks with the Matte Finish and so i got the Low Odor Clear Coatings (Matte) instead. I just found out that this Low Odor Clear Coatings is of latex enamel. Can i use this for my paper craft?
Thanks
Old 07-02-2008, 09:06 PM   #38 (permalink)
CardStalker
Default
I would think that it should be ok, but you might try it on some plane paper first, and then on something printed. Latex might be a bit more flexable. Let us know how you make out.
Old 07-02-2008, 10:38 PM   #39 (permalink)
oraclehara
Junior Member
Default
I was thinking if the latex enamel can't be used, i'll just go exchange for another type. Anybody have experience in this?
Old 07-03-2008, 11:47 AM   #40 (permalink)
timhinds1@cox.net
Default
I would try it first. latex is water based as is your printer ink. Let your test paper dry well as the ink might bleed during the drying process.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pull coating off foam or not 91rioja Technical Q & A 6 02-19-2007 11:24 AM
Sometimes, on a clear day, you can see... doctorwayne Photography, Books, Video, Scenery 10 04-25-2006 02:40 AM
Clear tape shepperdspie Drift Setup 12 10-07-2005 12:17 AM
Can someone help clear this up? vanda32547 DCC Forum 9 12-20-2004 06:28 AM
Inkjet surface coating and heat activated adhesive discovery Gil Tools of the trade 9 08-23-2004 07:22 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
