HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Card Models > Tutorials (institute of higher learng)
Reply
Thread Tools Display Modes
Old 03-01-2007, 04:33 AM   #61 (permalink)
PapaBear
Default
Anyone can easily learn to texture a model.
How good the texture ends up will also depend on your personal ability to paint or draw. Just because you have photoshop doesn't make you an artist.
As Art Decko said, a bit of patience, practice and eye for detail is a good start.
There are also some killer methods that can be learnt that will help greatly whether or not you are good at texturing a model.
If I have attached the images correctly, they are examples of game models which have been textured based on a game engine. The track on the Stug is in fact just a rubberband. The wheels look detailed, but trust me, they are solid with no bolts or even rim detail. Only the sprocket and idler wheels have very minimal geometry modelled.
Attachment 8028
Attachment 8029
The gun models are same but modelled for a PS2 game engine. They are very low poly but the detail is in the texture. Each weapon is modelled solid with no separate moving parts.
Its about understanding how the eye perceives what is believable, colors, contrast, light, shadows, etc. These concepts can be learnt and practiced.
PBear
PapaBear is offline   Reply With Quote
Old 03-01-2007, 08:14 PM   #62 (permalink)
Art Decko
Art Decko's Avatar
Default
Great examples of the power of graphics to convey detail!
This is what I mean when I suggest that some designers do not give sufficient attention to graphics. If the graphics are detailed and realistic, the "geometry" or "dimensionality" of the model can be *simplified*, even as the level of apparent detail increased!
As PapaBear pointed out, this practice is common in the pc game industry, where the "skins" are as important as the "wire frames" they are wrapped around.
Something for developers to consider: spending all that AutoCAD time designing tiny, perfectly-shaped scale parts may in fact not be the best way to develop a model. Spending less time on the geometry, and balancing it with more time spent designing realistic "skins" could lead to more convincing results, achieved with much less trouble for the builder.
After all, printable surfaces is one of the key distinctions of card modeling! Why not take full advantage of this ability instead of treating it as much less important than part design?
Art Decko is offline   Reply With Quote
Old 03-01-2007, 09:52 PM   #63 (permalink)
keith
Default
Quote:
Originally Posted by Art Decko
Yoohoo, any trained artists around cardmodel.net?
Yes, but we're all surrealists
I'll have a look in my old bookmarks, i think starship modeller has some nice weathering tutorials.
keith is offline   Reply With Quote
Old 10-03-2007, 05:14 AM   #64 (permalink)
Mace
Mace's Avatar
Smile Look what I found
I was searching in the deep corners of my HD because I remebered that Nobi created an AT-ST once using a game model and he'd written a tut about it.
Guess what, I found it
I attached it to this post (Hopefully)
It explains both Metaseq and later the unfold in Perpekura.
It might be a bit dated because he wrote it over 2 years ago but you might pick up a few tricks because Nobi is one of the best.
__________________
Ours is NOT to reason why, Ours is to cut 'n paste or die
Mace is offline   Reply With Quote
Old 10-03-2007, 01:16 PM   #65 (permalink)
Elliott
Card Models Moderator
Elliott's Avatar
Default
This is too good to leave buried away. Since this was originally posted on Cardmodels.net I have posted it in the Downloads section under Tutorials. Title is Convert Gaming Model into Paper Model.
Thanks Mace for bringing this out into the light!!
Elliott
Elliott is offline   Reply With Quote
Old 10-04-2007, 03:24 AM   #66 (permalink)
Mace
Mace's Avatar
Default
Yer Welcome Elliott
I started doubting myself because i couldnt find the post here anymore. And sorting thought about 2.5 gigs of papermodel-pdfs can be a bit fustrating aswell (I might need a new way of sorting my stuff).
Luckily I found it
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pepakura tutorial gman95687 Designer's Corner 12 01-05-2007 09:52 PM
Tutorial, welding for Pepakura. wunwinglow Software in Cardmodeling 2 04-13-2004 03:53 AM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
