HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Card Models > Tutorials (institute of higher learng)
Reply
Thread Tools Display Modes
Old 04-10-2007, 05:15 PM   #16 (permalink)
46rob
46rob's Avatar
Default
In that type of situation--you have to remember to curve the marking consistent with the lines of curvature in the conical projection. Without some really trick software--it would have to be done carefully by hand. I didn't feel that I wanted to get into a lot of that, as I was tryng to pick and choose only those things that would be appropriate to the level I writing for. There are a lot of other considerations to think about, when applying markings. Most problems can be solved intuitively. Using the methods I wrote about-- I have not trouble applying a marking across multiple sections. The key is practice in using the techniques.
There's no substitute for doing test build of the sections, though. One of the things that I do, is to print two copies of the test build...I build one, and then on the other, I make notations as to corrections needed. It's real easy when looking at the model to confuse right from left and top from bottom when you're comparing it with the screen. Writing it all up on a sheet (and double checking it) really helps.
__________________
Rob
More jets coming
46rob is offline   Reply With Quote
Old 04-11-2007, 12:33 AM   #17 (permalink)
Bengt Fredén
Bengt Fredén's Avatar
Default Recoloring Tutorial
Hi Rob,
THANK YOU for your efforts - this tutorial is very comprehensive and easy to digest. I will try to practice this method at my computer when I have a couple of days in a row. It would be very good to have the knowledge how to change the colors and certain textures.
Great work, Rob!
All the best,
Bengt
Bengt Fredén is offline   Reply With Quote
Old 04-11-2007, 07:41 AM   #18 (permalink)
-Jim G
-Jim G's Avatar
Default
Rob!
Your tutorial is fantastic! I have reread it a couple of times in the past couple of weeks and I find it helpful. I like your newest parts about aligning markings across seams.
I wonder if this forum should have a HELP section right up on the top where things like this tutorial could be posted ?
-Jim G
-Jim G is offline   Reply With Quote
Old 04-11-2007, 01:00 PM   #19 (permalink)
46rob
46rob's Avatar
Default
I actually tried to post it to this forum--but everytime I tried to upload the 2.5 M pdf--the upload failed (probably timed out). Best I could do was get FG to publish it and then post a link to it.
__________________
Rob
More jets coming
Old 04-11-2007, 01:05 PM   #20 (permalink)
Amazyah
Sr. Card Models Admin.
Card Models Administrator
Amazyah's Avatar
Default
Quote:
It would probably work if you were to split the pdf into two files.
The pdf upload only seems to work if your file is under 2Mb.
Russell
__________________
Selling off a good portion of my model collection.
Nothing up at the moment but I'll get some up soon.
http://search.ebay.com/_W0QQsassZcardmodelsnmore
Amazyah is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Coloring Sculptamold RobL Photography, Books, Video, Scenery 9 01-13-2007 06:51 PM
Edge coloring: What do you use? alfadoc Tips and Techniques 33 07-26-2006 02:28 PM
WS plaster coloring kit ddavidv Photography, Books, Video, Scenery 4 04-04-2004 10:50 PM
Edge Coloring JRSeese Tips and Techniques 1 04-04-2004 01:58 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
