HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Card Models > FAQ's (Frequently Asked Questions)
Support our community and these ads go away.
Reply
Thread Tools Display Modes
Old 06-26-2007, 10:04 PM   #1 (permalink)
red_starrise
Junior Member
Question Rescaling
Ok, I found some templates to build paper Games Workshop tanks made by a fellow who goes by Bile. They are in .gif format & they are HUGE for 28mm, I think in the current size they would be more like 54mm. Anyway, he says they should be printed at 26.0 cm high and 18.5 cm width. My problem is though that I don't have anything at my disposal besides typical paintbrush, works & wordpad. Could someone help me out here on how to do this? I mean, besides redrawing them in proper scale myself of course. Any assistance here would be great.
Thanks.
P.S. I am new to this forum but not to card models, I scratchbuild my own designs outta card all the time, though I usually print on standard paper & then glue the templates to cereal box card since mine are for wargaming they need that extra weight & sturdiness to them.
red_starrise is offline   Reply With Quote
Old 06-26-2007, 10:45 PM   #2 (permalink)
looker
Junior Member
Default
IrfanView - Official Homepage - one of the most popular viewers worldwide
change the size by changing the dpi setting
don't think gif knows how to remember what dpi it should be so it just defaults to 72 dpi and the pictures look huge
or maybe you can do that in Paint anyway
looker is offline   Reply With Quote
Old 06-26-2007, 10:51 PM   #3 (permalink)
looker
Junior Member
Default
maybe you can do this in Paint anyway
Old 06-26-2007, 11:24 PM   #4 (permalink)
cgutzmer
Reserves Librarian
Card Models Administrator
cgutzmer's Avatar
Default
It seems your size is twice as big as you want it and you are not looking for an exact scale correct? If a close approximation is good enough....
Open it in paint
choose image at the top and choose stretch/skew
change your horizontal and vertical to 50%
that should get you pretty close!
Chris
p.s. welcome to the fold and let me know if that worked for ya.
__________________
Looking for models - try the Zealot WIKI! Click here -> http://wiki.zealot.com/index.php/Free_Models
cgutzmer is offline   Reply With Quote
Old 06-27-2007, 06:55 AM   #5 (permalink)
MOS95B
MOS95B's Avatar
Default
If paint will open a gif file, all you need is Stretch/Skew and a bit of math...
__________________
Yet another John.....
I may not be as good as I once was
But I'm as good once as I ever was
surfduke's Moon Port Project - My builds
MOS95B is offline   Reply With Quote
Old 06-27-2007, 06:58 AM   #6 (permalink)
dansls1
dansls1's Avatar
Default
You should be able to do this in Paint using the stretch / skew feature.
__________________
-Dan
Gee Bee R1 - gremirmodels.com, Modelik BF109-G8 -> Complete
Halinski Mustang III -> In progress
dansls1 is offline   Reply With Quote
Old 09-20-2007, 07:00 PM   #7 (permalink)
gian7675
gian7675's Avatar
Default Help in rescaling this
Hi!
i was just wondering if you guys can help me rescale this 1:268 JMSDF Kongo into 1:200
Heppoko paper model studio
Can somebody give me some tips? I need to be spoonfed here because I'm not knowledgeable in computers...and I suck at math
All that I know is, this JMSDF Kongo is 1:268 and Ineed it to be in 1:200.amd that's it.
Can anybodyhelp?
Here are the specs of the real JMSDF Kongo
Length: 528.2 ft (161 m)
Beam: 68.9 ft (21 m)
Draft: 20.3 ft (6.2 m)
Anyway, when we've figured out the length of the JMSDF Kongo in 1:200, how long should I add to the 1:200 JMSDF Kongo to make it into a 161 m ship?
Thnaks!
gian7675 is offline   Reply With Quote
Old 09-20-2007, 07:44 PM   #8 (permalink)
rowiac
rowiac's Avatar
Default
You are going to need to scale up the model by 134% to make it 1:200. It's a simple calculation: 268 / 200 = 1.34 = 134%.
To deal with this problem in a simple way, you will encounter two problems:
The first problem is that at that size, it will no longer fit on A4 or Letter-size paper. The simplest way would be to get some A3 or 11X17 card stock and print it scaled up 134% at a copy shop.
The second problem is how to print it scaled up. The printer driver on my Canon inkjet printer has a feature in Page Setup called Scaled Printing. I can choose between 20% and 400% scaling. Not all printer drivers have that feature, however. For example, the HP color laser printer I have at work doesn't.
Another possibility is to extract the graphics directly from the PDF and save them as a JPG or other image type. Using a graphics program, you could then scale them up, rearrange the parts onto A4/Letter size sheets and then print. Unfortunately this particular PDF is secured and won't allow you to directly extract images.
There is no simple answer for this one that I can see, and at 11 sheets in size, it will take a lot of manipulating to get what you want.
Roger
__________________
WIP: Yamaha YZ450FM
rowiac is offline   Reply With Quote
Old 09-20-2007, 07:54 PM   #9 (permalink)
rowiac
rowiac's Avatar
Default
P.S. (couldn't get Edit to work to add this to my previous post)
A 161m ship at 1:200 scale will be 161 / 200 = 0.805m = 80.5cm (= 31.7") long.
At 1:268 scale, the model will be 161 / 268 = 0.601m = 60.1cm (= 23.7") long.
__________________
WIP: Yamaha YZ450FM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
HELP -Rescaling from 1:50 to 1:32, 1:33 dimas Karabas Tips and Techniques 10 05-11-2005 09:42 AM
No brain rescaling Darwin Tips and Techniques 4 03-11-2005 05:43 AM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
