#1 (permalink) |
Junior Member
I'm considering build my n-scale layout to bentrack standards and was wondering if anyone here could possibly give me some module ideas. I am planning to build in stages, thus I am going modular and I like the bend track system.
#2 (permalink) |
Hello, the N scale group of our club built a bend track layout, although we have been rather loose with the electrical standards and table height.
2005 Show These pictures are from 2005 but they show the vast majority of the modules, the only one that has been added is mine that is in my signature. All the pictures that have skyboards are the N scale ones. Currently they are all set up in my garage. I am building another 90 degree turn module so that I can filt the whole layout in my garage space (24' x 10'). Other modules that we have been tossing around: major bridge, coal mine, passenger station, waterfall, timesaver puzzle, Inglenook sidings, amusement park, other operations modules.
__________________
Scott My Layouts: New Desktop Layout, Inglenook, Baseball Module, Desktop Layout, HO Layout. |
#3 (permalink) |
Junior Member
Bend Track is great. I started the group Jesso belongs to. I choose bend track to be my home layout which with time has grown to the group of modules that you see now in the pictures.
The only change we made was to shorten the legs to n track height which is easier for kids to view at shows. |
#4 (permalink) |
Junior Member
We have a Bend Track Group in Prince Albert. Sask. Canada. We have found that the concept is very good, with many different variations of arrangements that can be done. I am not a big fan of the N-Trak with the 3 main lines. I also like that you can start with 2 balloon ends for the beginning of the layout and expand later.
Brian Randall |
#5 (permalink) |
What are you interrested in? I have found that a great way to come up with a layout idea is to look at the prototype for ideas. Many times a large industrial complex can give you a layout idea that will fit your space.
#6 (permalink) |
Junior Member
Wow, Thanks for the responses, I should of tracked this thread better. Right Now I have two six foot modules built. No track is down at the moment as I have been experimenting on how best use my space. As I do this, I keep coming back to the bend track system as a easy way to expand.
Russ, I have an assortment of cars: Coal hoppers, Box cars, covered hoppers (grain/ chemical / plastics) and a few tank cars. What I am looking for is an modern (mid90/s+) industry that will take boxcars, tankers and covered hoppers. I think I would like to stay away from a grainery type of setup and go for either a paper mill or auto industry set up. I once found a web site for a man named Andrew Martin that had a lot of industry layout plans (ho I beleive, but easy to rescale) but now I can't seem to find it. Locally, on my way to work, I drive past a local coal power plant. So I know how I want that to go and it is very easy. So now I need to get a digital camera so I can share it. It is basically a two track siding (next to a double main) with a spur leading into the power plant. each track holds approximately 25 cars, each is split about 15 cars back for an access road. Also there is a lead for the 44 ton switcher so it never enters the main. I'm not exactly sure of the plant trackage, but I think it has atleast two tracks. I would model it as implied by just running of the edge of the layout. |
#7 (permalink) |
Junior Member
If you look at the top picture of the yard, there is a track that runs up the middle of the elevator module that connects to a balloon module with a paper mill in the middle. Where the caboose is, there is also a small engine shop with my mill switcher for it. Hopefully this will give you some ideas.
Brian Randall |
#8 (permalink) |
Midwest Alliance Rail Sys
I've looked at a lot of modular specifications (even though no part of my HO layout is intended to be transported, e.g., to a show). I like the efficient use of space of Bend Track; my primary concern is the "S" curves in the balloon modules.
#9 (permalink) | |
Quote:
__________________
Scott My Layouts: New Desktop Layout, Inglenook, Baseball Module, Desktop Layout, HO Layout. Last edited by jesso; 12-22-2007 at 05:19 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Do Not Bend | Rodney | Archives | 64 | 09-12-2005 06:03 AM |
| I know it's small but should it bend like that? | chip | Track Planning | 20 | 01-16-2005 06:55 PM |
| Shay rounds the bend. | shamus | Photography, Books, Video, Scenery | 12 | 02-04-2004 06:48 PM |
| Big Bend | Matthyro | N / Z Scale Model Trains | 12 | 04-14-2003 09:21 AM |
| How do you pre-bend rail? | Hunkiedoo | Technical Q & A | 8 | 01-09-2003 10:22 PM |
