HobbiesHobby ForumHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Card Models > Card Modeling
Support our community and these ads go away.
View Poll Results: Dark outlines on parts?
Great idea! It always helps making a clean and accurate cut. It's definitely a must. 30 38.96%
Do you have those lines on the real thing? If not then I don't want that on my model please. 20 25.97%
Fine with either, don't mind and don't care. 19 24.68%
Never gave a thought about that... 8 10.39%
Voters: 77. You may not vote on this poll
Reply
Thread Tools Display Modes
Old 12-16-2007, 10:58 PM   #31 (permalink)
Gainer
Default
For me, depends on how im displaying. If it is a NICE disply piece NO lines please. If just a quik project for fun, doesn't make a difference really. Also depends if im at home(using x-acto blades) or on the go(using a pair of scissors)
Just an opinion
__________________
Some models were just not meant to be...
Gainer is offline   Reply With Quote
Old 02-02-2008, 04:19 PM   #32 (permalink)
Elliott
Card Models Moderator
Elliott's Avatar
Default
With less than perfect older eyes I need some contrast. However the solid black on many models is overdone even to my eyes. I like the idea of the gray shading.
__________________
Elliott
Semi-senior membah
Redneck Paper Modelahs
Elliott is offline   Reply With Quote
Old 02-11-2008, 03:39 PM   #33 (permalink)
blueeyedbear
Default
About black outlines: try both cutting with the line on the part and cutting the line off of the part. Which fits best? Go that way! An alternative is to cut on the middle of the line. Fit of the parts is more important than anything else.
About score and fold lines: on the part, ONLY if the line is a part of the model's detail. And BIG and BOLD pointer marks outside the part.
And for eyes as old as mine(76 years of use in April): get an OptiVisor (check the MicroMark catalog and web site, as well jewelry and beading websites. Some hobby and craft shops carry them). You can get several different lenses, depending on how much magnification you want/need. A light on the OptiVisor is nice --- I have a CHEAP head lamp mounted on mine. [OptiVisor brand magnifiers have GOOD lenses, much better than similar and cheaper ones] I also Googled for reading glasses (which I HAVE TO use to see closer up than about 15 feet!) and found a source for "4's" (very hard to find stronger than "3's").
Bob
blueeyedbear is offline   Reply With Quote
Old 05-11-2008, 06:07 PM   #34 (permalink)
keith
Default
For white models, black outlines are essential
If you print reversed you can turn the part inside4 out!!!!
For models with lots of textures, i leave them out. Unless the texture is too light in which case a stand-off line 1 or 2 pixels away from the edge is used. Quite easy with modern software. And cut inside the line without leaving any line showing.
With modern printers it should be posible to print the cutting lines on the reverse of the sheet, though i haven't testing it yet with my small parts.
keith is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
I want to ask you the most important question of your life. The question is: Are you saved? It is not a question of how good you are, nor if you are a church member, but are you saved? Are you sure you will go to Heaven when you die? The reason some RLG101126@yahoo.com Archives 24 05-25-2005 12:01 AM
I want to ask you the most important question of your life. The question is: Are you saved? It is not a question of how good you are, nor if you are a church member, but are you saved? Are you sure you will go to Heaven when you die? The reason some RLG101170@yahoo.com Archives 1 05-24-2005 12:01 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is not a question of how good you are, nor if you are a church member, but are you saved? Are you sure you will go to Heaven when you die? The reason some RLG101148@yahoo.com Archives 3 05-22-2005 09:01 PM
Re: Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Proginoskes Archives 0 04-21-2005 11:00 PM
Lifting outlines in photoshop Darwin Software in Cardmodeling 3 01-03-2005 09:59 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
Powered by vbWiki Pro 1.3 RC5. Copyright ©2006-2007, NuHit, LLC
