#151 (permalink) |
1:20.3 Train Addict
The Gauge Administrator
nice stuff!!! Coming along really well!!!
__________________
~~ Mikey (Admin) ~~ NARA Member # 101 ~~ Link To J.G.B.S.M.F. & W. RR Web Site ~~ Link To E-Mag Information ~~ I wonder what that would look like in 1:20.3??? |
#152 (permalink) | |
__________________
Follow progress on My Missabe layout Check out My construction diorama And remember, the light at the end of the tunnel could be an oncomming train. ![]() |
#153 (permalink) |
One month huh? WHERE THE HELL HAVE I BEEN? Time to get back back into it I guess.
__________________
#154 (permalink) |
__________________
#155 (permalink) |
Kevin, I just saw your pics of the tree you made. It is similar to a redwood, but I'm not sure it matches anything found in the Minnesota North Woods. A cheap source for pine trees would be "bumpy chenille." I think it is available in a craft store like Micheal's or the craft section of Wal-Mart. It is green fibers on twisted wire in 2 or 3 foot long sections. It can be cut into individual trees. They are not good foreground trees, but would work to fill out a forest behind your good foreground trees. If you have some hardwood forests to model in summer, you might start with your dowels, and drill some small holes to glue in round tooth picks for branches and then glue on the ground foam to your new tree armatures. Since the branches will be dead straight, you would again need to use them behind better looking trees for the fore ground. An even easier way to make a hardwood tree is to get some mechanic's wire (safety wire) from an auto parts store or home improvement store, and cut 6-8 peices of wire about 6 inches long. Twist the wires together for about 1/2 inch or so, then separate a couple of wires and twist them together for the lower branch, separating them to individual branches part way out. As you go up the trunk, repeat the process until you have a nice tree armature. Finally wrap a bit of masking tape around the bottom 1/2 inch of the trunk and paint it a gray color to simulate the trunk. Then dip the armature in your ground foam after putting some sort of fixative (hair spray, spray glue, etc.) on it.
#156 (permalink) | |
Quote:
I've been thinking of starting collecting that kind of DM&IR stuff also. Chris
__________________
Light travels faster than sound. That's why people appear bright until you hear them speak.-Unknown |
#157 (permalink) | |
__________________
#159 (permalink) |
I had a '64 Chev 1/2 tonnner, with a wide rear window, a souped up 327, dual exhaust and Blue Missile mufflers. It was a four speed, and I loved to downshift into third, and let the engine be my brakes, when comming down Oak Creek canyon. Some times I'd grab second gear around the tightest switchbacks, and I really loved the sound of those pipes echoing off the canyon walls!
__________________
The "other" engineer. USACE |
#160 (permalink) |
Sounds like a sweet truck.
__________________
#161 (permalink) |
The brigde crew sufferesd some serious delays, and will now be getting "back on track" and the bridge should soon be up. The supports are the last step of the process. Ill head down and take some pics of the crews progress later on if I get the time.
__________________
#163 (permalink) |
__________________
#164 (permalink) |
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| cuustom missabe loco | Kevinkrey | Scratchin' & Bashin' | 4 | 05-27-2007 09:47 AM |
| Layout progress | Saddletank | General Talk | 6 | 01-08-2007 10:58 PM |
| Layout progress | JKountz | HO Scale Model Trains | 25 | 01-24-2006 04:50 PM |
| My first layout in progress | cpNscale | N / Z Scale Model Trains | 9 | 12-02-2003 12:09 AM |
| layout progress | John Sneed | General Talk | 5 | 04-20-2003 06:20 PM |
