HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > The Gauge - Model Trains > New Model Railroaders > The-Gauge: Navigation Guide
Reply
Thread Tools Display Modes
Old 12-28-2007, 07:39 AM   #1 (permalink)
Bigguy
Junior Member
Default Another newbie
This is my first post. I just discovered this site yesterday. There is a whole lot of great information here. I recently set up a 4 1/2 by 8 table with a double loop HO track set up with DCC.
So far, I am having some derailment problems; they seem to be happening most at a 19 degree X crossing. I am using Atlas Code 83 track. Any suggestions?
Bigguy is offline   Reply With Quote
Old 12-28-2007, 09:37 AM   #2 (permalink)
scubadude
scubadude's Avatar
Default
__________________
Cheers,
Richard
scubadude is offline   Reply With Quote
Old 12-28-2007, 10:02 AM   #3 (permalink)
Herc Driver
Herc Driver's Avatar
Default
Welcome and congrats on finding the best place on the web for info and knowledge about trains. There's plenty of folks here who have some great skills and experience that freely share and try to help.
Are the derailments occuring with the engine or on some cars? First and easiest thing to check...with an HO Standards gauge, check the space between the wheels of everything. You'd be suprised just how many wheels sets are close but not exactly spaced correctly out of the box. Next, I'd suggest taking a magnifying glass and closely look at the entire X-crossing for plastic burrs that might be affecting a wheel as it goes through the intersection. Also, with a gauge, check the rail spacing as it's possible that the width between the rails is too narrow causing a wheel to ride up and out. Are there curved track sections right before the X-crossing? It's possible that the radius isn't quite right to straighten the cars out just before entering the crossing and if there's any coupler problems, the end result might be a derailment at the crossing that had its start a few inches prior. Finally, it could be the wheels themselves. I'm just learning about the various track codes and which wheel works best on what code. But I've seen on my layout that some wheel types (Low rise vs. High profile - if I'm using the terms correctly) do better than others and where I notice it is over the turnouts I'm using. I can always count on a derailment from a light weight car using a low profile wheel, so I try to make sure the car is correctly weighted and has he higher profile wheels. That may not be quite prototypical, but it keeps the derailment gremlins at bay and allows me to run a train with no derailments for hours.
But there's plenty of guys here with way more knowledge than me who could add their two cents...
__________________
Flying the Herc to pay for the trains!
Herc Driver is offline   Reply With Quote
Old 12-28-2007, 10:21 AM   #4 (permalink)
Bigguy
Junior Member
Default Thanks
Thanks for the good info. I will get a gauge and check the spacing. The derailments seem to occur most with small hopper cars. I will try to put some weight in them to see if that helps.
Old 12-28-2007, 11:23 AM   #5 (permalink)
stripes
Default
Well it seems like you got good advice from Herc Driver so there is noting left for me to say but, WELCOME!!
stripes is offline   Reply With Quote
Old 12-28-2007, 11:29 AM   #6 (permalink)
Nomad
Nomad's Avatar
Default
Welcome to The Gauge, Big Guy.
Loren
__________________
You can't help getting older, but you don't have to get old.
George Burns
Nomad is offline   Reply With Quote
Old 12-28-2007, 03:02 PM   #7 (permalink)
Jim Krause
Default
Welcome. Weight, or lack of, can also cause derailments, especially if you are using the plastic cars that come with a train set. Try adding some pebbles to your open cars to see if it makes a difference.
Jim Krause is offline   Reply With Quote
Old 12-28-2007, 04:22 PM   #8 (permalink)
Herc Driver
Default
I know there are suggested weights available on the NMRA website if memory serves me correctly. They post a formula for the car's basic weight plus a fractional ounce per inch of car (or something like that). I had similar problems with my Nscale layout and after weighing a random sample of various manufacturer's cars, I found some to be under weighted, which seemed to contribute to the derailments at the turnouts.
__________________
Old 12-29-2007, 11:49 AM   #9 (permalink)
PWRR-2207
Rogue Islander
PWRR-2207's Avatar
Default
Welcome aboard! [NMRA HO Car weight formula is 1 ounce plus 0.5 ounces per inch of car. It made a big difference on the performance of my under weight cars.]
__________________
Providence & Worcester Railroad,
Engine 2207
PWRR-2207 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Another Newbie fotojunkie Introductions 2 01-29-2008 01:36 AM
Newbie in DCC Railroy19 DCC Forum 12 05-17-2006 04:48 PM
newbie needs some help !! darius28z HO Scale Model Trains 5 11-28-2005 10:45 PM
NewBie Pls Help SiDeWaYz RC Drifting 3 05-29-2005 06:15 PM
Newbie needs help..please psocks Scratchin' & Bashin' 5 11-20-2003 09:08 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
