HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Specific Model Categories > Armor and Military Vehicles
Reply
Thread Tools Display Modes
Old 05-10-2008, 09:51 AM   #61 (permalink)
lriera
Default
Hello companions,
Kevin, thank you for your encouragement. Following the Willys I am thinking about some architectural "délicatesse", the Renova Model Studnia Kazimierska to take a break from the military vehicle saga. But after that, in my ToDo list, I have the Renova Model H.L. Hunley, the Orlik P-47 D-11 Thunderbolt and the GPM M4A3 Sherman. So... a lot of work.
Today another little advance with the Willys. The bumpers and stick the body to the main frame.
In photo 272 you can see the pieces that compose the bumpers, before trimming them. I have already stuck on card piece 26. In Photo 273 all the trimmed pieces with all the painted edges. All? A little piece does resist to being occupied by the Roman invader… ah, it seems to me that I am getting confused of history (do you know the French comic Asterix?). No, not all are painted, as always; I realized the forgetfulness when seeing this photo. Luck, because if no, another “small disaster” to the saga of the errors.
272. 273.
In Photo 274 all the stuck pieces to each other, ready to glue them to the frame.
274.
And in Photos 275 and 276 I have already stuck the bumpers to the frame. Taking advantage of the occasion I also have stuck the hook of tow in the back of the frame.
275. 276.
Finally, in the series of photographies 277 to the 280, you can see that I have already stuck the body to the frame. Now it is that the Willys already seem a car. It is the moment that I hoped. Now I see the LIGHT at the end of the tunnel!
277. 278. 279. 280.
Thanks to all for your encouragements, they have really helped me to arrive up to here.
Greetings and, I hope, until soon.
__________________
Lluis Riera
Finished: Willys Jeep from Modelik.
Finished: Kettenkrad Sd kfz 2 NSU from Modelik.
lriera is offline   Reply With Quote
Old 05-10-2008, 04:31 PM   #62 (permalink)
Rick Thomson
Rick Thomson's Avatar
Default
Very nice.
I have a soft spot for the Willys Jeep as it was my flightline vehicle during a fair bit of my service in the Canadian Airforce. I had dragchutes stacked three deep on the hood, and in the back seat area as well as beside the drivers seat. Generally there was a Liquid Oxygen trailor hooked up to it as well.
Rick
__________________
Remember...any tool can be the right tool.
Keep your stick on the ice.
Rick Thomson is offline   Reply With Quote
Old 05-11-2008, 08:50 AM   #63 (permalink)
lriera
Default
Rick I agree with you. This is a very good vehicle, and a very good model.
I am enjoying very much this build, and more with all your support.
Thank you everybody.
__________________
Lluis Riera
Old 05-12-2008, 12:47 PM   #64 (permalink)
ml5716111
ml5716111's Avatar
Default
This beautiful jeep brings memories from over 45 years ago. It was my father's first car and we used to ride it many times, from the mid 1950's to the late 1950's.
Moshe
ml5716111 is offline   Reply With Quote
Old 05-12-2008, 01:37 PM   #65 (permalink)
lriera
Default
Hello companions,
Moshe, I am been charmed with of that my build brings to you agreeable souvenirs.
Now it seems that this build finally advances quicker. Because it seems that what I am doing now is to be filling the body and finishing components of the Willys.
First, today, it has been the turn of the fuel tank, for that reason in Photo 281 you can see, as always, the pieces before cutting them. But this time, I have forgotten to take the following photography with the cut pieces and some of the process of assembly of the top part of the fuel tank. So in Photo 282, surprise!, it appears the top part of the fuel tank already mounted and I begin to mount the bottom part. As always, first I stick one side and, when it is dry, the other, one behind another one.
281. 282.
Also I have skipped some passages of the bottom part of the fuel tank, and thus in Photo 283 I show you the two parts of the fuel tank already finished. I hope that you will pardon this lack of photographies.
283.
In Photos 284 and 285 a view from down and another one from above of the two parts of the fuel tank already stuck in its place in the Willys.
284. 285.
The second part of the today tasks have been to mount the grill and the lateral protectors of the engine. In Photo 286 you can see the pieces that compose this part of the assembly and in the Photo 287 the pieces cut, with painted edges and ready to be mounted in the frame.
286. 287.
In Photos 288, 289 and 290 I show you how I have held the bottom frontal grill to the frame while stuck, by pressing it with small pliers, and then the top part with an improvised press with different tools. Finally, in Photo 290, the frontal grill already stuck in its place.
288. 289. 290.
In Photo 291 I am sticking to the frame the left frontal part of the protector of the engine. In Photo 292 I am sticking the right frontal part and the piece that go between this one and the body.
291. 292.
And finally in Photos 293 and 294 I show to you the aspect of the Willys until now with the works carried out. As you can verify the Willys every time is “fuller”.
293. 294.
Well, that is everything for today. I hope that soon I can show new advances to you.
Until then.
Greetings to all.
__________________
Lluis Riera
Old 05-12-2008, 04:57 PM   #66 (permalink)
Dalmi
Junior Member
Default
Very good teacher
Dalmi is offline   Reply With Quote
Old 05-12-2008, 05:22 PM   #67 (permalink)
lriera
Default
Dalmi, you are exaggerating, I am just learning.
But, thank you.
__________________
Lluis Riera
Old 05-13-2008, 02:42 PM   #68 (permalink)
lriera
Default
Hi folks,
This moves more and more fast.
Today it was the turn to the front mudguards of the Willys. The single problem that I have found is that there is one narrow strip of paper that borders and gives outer form at the mudguards and has been a little laborious to obtain that it stayed in his place, but at the end, and with a little patience, I have obtained it.
In Photo 295 you can see, as always, the pieces that compose the mudguards before cutting them. And in Photo 296 those same pieces already trimmed.
295. 296.
In Photo 297 the face and the back of the mudguards and the strip that outlines them are sticking. First I fold the pieces separately and later I stick one against another, this way they maintain its form far better. And in Photo 298 the folded part of this small strip of paper is sticking.
297. 298.
In Photo 299 I am sticking the bottom reinforcement of the mudguards and in Photo 300 you can see the global look of the Willys with the stuck mudguards. You are going to agree with me that it already seems a Jeep, right?
299. 300.
Well, for the present time nothing else, but soon I will return with new updates. Now the build is going at top speed, and I am happy.
Greetings to all.
__________________
Lluis Riera
Old 05-15-2008, 04:54 PM   #69 (permalink)
lriera
Default
Hi buddies,
As far as the Willys… this moves… this advances without stopping.
Today it has touched the turn to the steering wheel, the pedals and the battery. In Photo 301, the pieces that compose the pedals and the steering wheel of the Willys. And in Photo 302 you can see mounted the pedals, the axis of the steering wheel and trimmed and painted the same steering wheel. The supports of the pedals are maintained by the very small end of the paper, but with a drop of glue, they do not mean any problem.
301. 302.
In Photos 303 and 304 two views of the finished steering wheel. Some companions of other Forums have used different materials. I use the paper, not by purism, but because I am learning to handle scales and textures, and I still do not dare with nothing else. Mainly after the poor result with the cables of the spark plugs (yes, yes I take them nailed in the heart, but I want to obtain satisfaction).
303. 304.
And in Photo 305 the pedals glued in its place in the body. I do not know why it serves the black button underneath the accelerator pedal, but the instructions indicate that this is its place… and there is. Also what I said before, the pedals are maintained by that very small end of paper, but just as before, a drop of glue… and it already is. They are self-sustained.
305.
And now it is the hour of the battery and the other box close to him that I do not know what it is. In Photo 306 the pieces before being trimmed. And in Photo 307 the pieces once passed through the edge of the cutter, with the folds already done and the edges diligently painted.
306. 307.
In Photo 308 I have already stuck the two boxes. The paper goes edge against edge, without flaps, but given the size, with a few drops of glue, and holding them with my fingers while this one is dried, I obtain that they maintain his form. And in the Photo the 309 two finished boxes.
308. 309.
Photo 310 shows the first box stuck in its place. For the battery, its position is only indicated with a points line. As it seemed to me excessive to stick the battery only by the edge, I cut and stuck a card plaster of 0.5 mm, a little below the line of points, so that the battery stayed to its correct height. And in the Photo the 311 two boxes in its place.
310. 311.
That is everything for today, tomorrow more. Well, I do not know if tomorrow, but certainly in a moment.
Greetings to all.
__________________
Lluis Riera
Old 05-16-2008, 09:53 PM   #70 (permalink)
bclemens
bclemens's Avatar
Default
Coming together nicely, Lluis!
__________________
New Embossed Paper for your models available at AvantCard.biz
Free 1/33 Tug for your Airplane
http://AvantCard.biz
Currently designing 1/33rd Yak 15- Thread here:
http://forum.zealot.com/t156682-5/
bclemens is offline   Reply With Quote
Old 05-17-2008, 01:23 AM   #71 (permalink)
HeavyKevie
HeavyKevie's Avatar
Default
Lluis,
What do you use to color your edges?
__________________
Trifles make perfection, and perfection is no trifle. -Michelangelo
HeavyKevie is offline   Reply With Quote
Old 05-18-2008, 05:33 AM   #72 (permalink)
grzechu pl
Junior Member
grzechu pl's Avatar
Default
Lookin nice so far, keep it up
grzechu pl is offline   Reply With Quote
Old 05-18-2008, 12:54 PM   #73 (permalink)
lriera
Default
Hello to all,
Bruce, thank you for your nice words, they are very helpful. Kevin, I use a Caran d'Ache green marker, Ref. 185-249. Grzechu, thank you, I am traying to do my best and learning a lot on the way. Thank you all for your support.
And today new advances in the Willys Jeep. This time it has been the turn to the horn and the instrument board.
In Photo 312 you can see the pieces that compose the horn stuck on corresponding cardboards and in Photo 313, all the cut pieces, with the painted edges. But I had a problem with the horn. It is that tiny piece that you can see coiled at the end of a small stick. The problem is that it did not seem to me that it had left with the correct size, seeing threads of construction of other companions. So armed with Corel Draw, I drew a piece like the one of the horn, but I made it double size and after that, I print it, as you can see in Photo 314. The piece trimmed to the right is the original one, the one at the left is the one that I drew.
312. 313. 314.
And in Photo 315, you can see the horn already mounted. I like more my version than the tiny horn that had stayed if I had used the original one. In Photo 316 you can see the aspect of the horn in its place, in the Willys.
315. 316.
Next I have dedicated myself to the console of instruments. In Photo 317, as always, you can see the pieces before the cut, and, those that need it, already stuck to corresponding cardboards.
317.
In Photo 318 all the pieces already cut and with the painted edges. And in Photo 319, all the pieces stuck in its place in the panel.
318. 319.
Lastly, in Photo 320, the instrument panel beaten in its place in the Jeep.
320.
Good, so far already it is, but soon I will follow with more. And what follows they are the seats.
Greetings.
__________________
Lluis Riera
Old 05-18-2008, 07:37 PM   #74 (permalink)
kenlwest
Default
Llouis,
Great job and it's coming along nicely. Was the horn designed too small, or was it just too small to build. I have this model and will build it some day.
Ken
kenlwest is online now   Reply With Quote
Old 05-24-2008, 04:34 AM   #75 (permalink)
lriera
Default
Hello companions,
Ken, thank you for your encouragement, at this phase of the build it is very welcome. About the horn, I think it was designed very small.
Today it has been the turn of the back seat. Indeed, as I have no idea of by where begin, I have thought that if it left bad, probably it was going to be less noticed the back seat, that one of the forwards. So, with many doubts, I have confronted this task.
I say doubts, because as it often happens to me, after sticking the pieces on cardboard, trimming them and painting the edges, still I do not have any idea of which is the work order. It is that the instructions in Pole are a torture, because you know that there is explained everything but you do not understand anything.
Well, then with these doubts, I confronted the construction of the back seat and naturally it went bad. Luckily it was nothing almost burdens, because the glue still was not dry, but almost... Now with the story.
In Photo 321 you can see, as always, the pieces before trimming them. And in Photo 322 the trimmed pieces. I have already stuck the cover of the base and the back of the seat as always, going step by step. For that reason I have begun sticking the back part. In Photo 323 I already have stuck all the cover of the base and the back of the seat and I am proceeding with the same form with the endorsement. And in Photo 324 already the base and the endorsement are stuck.
321. 322. 323. 324.
In Photo 325 I have joint the three pieces of paper that form the support of the endorsement and I am coming, step by step, to stick it around the base of the seat, beginning by the center. Serious mistake! Because in Photo 327 I realized that when the strip arrived at the center, the endorsement of the seat was twist, more rised of a side than of the other.
325. 326. 327.
So I took it off, luckily it don’t suffered “collateral damage”. And in Photo 328 it is seen how I returned to stick it, this time, beginning from the center.
328.
Soon I fitted the endorsement, centering it in the superior part of the paper strip. The result was optimal, as you can see in Photo 329, with the finished seat.
329.
Good, now to by the front seats that, I hope, will be to me easier thanks to the acquired experience today.
Until in a moment with more news of the Willys.
Greetings.
__________________
Lluis Riera
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Willys jeep 1/25 zhang9889 Armor and Military Vehicles 4 01-24-2008 10:27 PM
willys jeep black & white maybaygiay Armor and Military Vehicles 31 10-25-2007 03:16 AM
Willys Jeep, Modelik 10/02 /1:25/ Bernie Armor and Military Vehicles 32 11-14-2005 03:27 AM
*Finish* Willys Jeep, Modelik Nr. 10/02, 1:25, Special Build fuchsjos Armor and Military Vehicles 169 09-21-2005 08:57 AM
WILLYS JEEP, 2--1950's Keychains: Honduras & Costa Rica --- Archives 0 05-23-2005 12:01 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
