#1 (permalink) |
with the intention of adding the aforementioned detail to models(mainly armour) i purchased a screw punch and tested out the manufacture of scale rivets on the wreak of my mk 4 and parts of other kits it works fine i even have a trick to paint the edges of a whole bunch of tiny disks at once....but one thing that seems to be going wrong is that the little disks are de-lamiating which is anoying a makes them look unsightly is there any way to treat the source matirial(what the disks are cut from) to prevent this? onece on the model a coat of varnish will keep them together but they tend to do it in assembly ...any ideas?
__________________
recent completion Schienen-panzer STEYER
#2 (permalink) |
Have you laminated the pieces? What kind of glue do you use?
I was using a transparent glue for the laminating process and the pieces also tend to delaminate, now I use white glue (wooden, not diluted) and it don't has happened to me anymore. I hope it will help.
__________________
Lluis Riera Finished: Willys Jeep from Modelik. Finished: Kettenkrad Sd kfz 2 NSU from Modelik. |
#3 (permalink) |
Maybe putting some CA glue on the sheet and letting it soak in. It tends to darken the colours a bit. I have used CA glue before when pointy parts of an architectural model decided to delaminate. I have also coated the gear teeth on some mechanical models to strengthen them and keep them from delaminating. Test it out and see if it helps.
#4 (permalink) |
I have some experience in making rivets....I have done a few thousands.
The clue is to not use thicker paper than 0,2mm.Cardboard will delaminate. The size/height of a rivet in real life is often less than 1cm,so 0,2mm in 1:25 scale isn't that far away. So what I do is to use the screw puncher and make rivets out of the same paper thats in the kit.Often there are color samples in the kit for spare use if you mess up parts,so I just make rivets out of that. |
#5 (permalink) |
I'm not sure that simply sticking card disks onto a model to represent rivets is the best that can be done. I looked at this a while ago and found a reasonable technique was:
- cut out the disks with a punch - edge colour the disks - shape the disks to a dome shape with an embossing tool. If there is a tendency to delaminate dip the emboss tool in diluted white glue then form the shape. The white glue seems to help the embossing and sticks the paper layers together. - glue on model taking care not to flatten the shape. Attached is an unfinished T-27 model with rivets made with this technique. The model looks crappy mostly because I had use flash to get an image. Regards, Charlie |
#6 (permalink) |
All small parts delaminate it is due to how they make paper, soft-core hard surface. What I have had good success with is “painting” the backside/unseen side of the paper with Future floor wax. Thanks to Peter Crow for this tip. Future appears to soak into the paper and bonds the fibers. I also use this method to stiffen up the paper to make fine cuts. The paper does not seen to tare as easily when you are cutting that strip of .5 mm paper.
__________________
Keep the peace(es). |
#7 (permalink) | |
Quote:
__________________
#9 (permalink) | |
Quote:
__________________
#10 (permalink) |
Same topic - different method......
I was struck the other day by the Braille imprints on an aircraft boarding pass - I'd guess the boarding pass was 120gsm card - the Braille imprints were a perfect rivet shape. Anyone know how this is done? Regards, Charlie |
#11 (permalink) |
Yes, they are done with a special machine. Not to consider for card modelling.
__________________
#13 (permalink) |
Thanks for that great biro tip, as well as the one about painting the little stacks of discs as a single cylinder. Clever ideas! I am always looking for "mass production" techniques like that. When my screwpunch arrives, I'll try that one!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Rivets | paul a | Tips and Techniques | 25 | 04-22-2007 11:37 AM |
| Brass rivets | straight-track | Technical Q & A | 3 | 04-18-2007 09:49 AM |
| Should I cut out before laminating? | tf34mech | Card Modeling | 8 | 02-05-2007 03:13 AM |
| Making Rivets | TomPM | Technical Q & A | 6 | 04-23-2004 02:24 PM |
| Rivets | Edavillenut | Scratchin' & Bashin' | 14 | 08-05-2002 10:59 PM |
