HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > The Gauge - Model Trains > Model Railroading > G / O / S Scale Model Trains
Reply
Thread Tools Display Modes
Old 03-25-2008, 02:33 PM   #1 (permalink)
Malcolm G. Stewart
mgstewart
Default Tunnel Warning Signals
A spur of the G-Scale, Digitrax DCC-RC, Penobscot & Pee Dee Railroad runs thru the Big Mountain via an 11' North/South-oriented tunnel. There isn't a set schedule; trains run in either direction as business dictates. Folks living in the North Village use the tunnel to visit friends in the South Village and vice versa. The P&PD RR cannot afford a full-time watchman for this infrequently used tunnel but, out of concern for the safety of the villagers, desires to install Dallee #557 beacons at the tunnel portals to flash warnings when a train approaches from either direction.
The concept is that a sensor will be installed an appropriate distance from the tunnel portal which, when triggered by the passing engine, will initiate the beacons. [The "appropriate distance" being sufficiently long to allow a tunnel walker to exit before the train enters.] After the train exits the tunnel, the engine passes a similarly distanced sensor and the beacons will be shut down.
Matters are straightforward for the Southern approach. This is a single track of sufficient length to accomodate placing the South sensor that "appropriate distance" away from the South portal. But things are not so easy for the Northern approach. An East/West main line runs close by the Northern portal and the track exits the tunnel into a right turnout (i.e., turns East) onto the East/West main line. There is not an "appropriate distance" between the North portal and the turnout. To provide the "appropriate distance" the North sensor must be located beyond the turnout, somewhere along the East leg of the main line.
The above sensor placement will work as desired for tunnel traffic but any main line train proceeding in either direction along the East/West main line would falsely initiate the tunnel beacons--and they would remain operating indefinitely. To prevent this false alarm, the beacon circuitry must be conditioned by the status of the turnout: When it is open (i.e., routing traffic thru the tunnel), the beacon circuit is switched "on"; when it is closed (i.e., traffic moves along the main line), the beacon circuit is switched "off".
[It follows from the above that, when the turnout is open, traffic cannot move Eastward on the West leg of the main line. And, when the turnout is closed, traffic cannot move Northward thru the South tunnel portal.]
I have three questions concerning the above scenario:
1. I would like to have a klaxon (or clanging bell, siren, what-have-you) incorporated into the beacon circuit. I've drawn blanks in my Googling; any suggestions?
2. I haven't a clue as to what hardware is needed to sense and control the warning signals as outlined in the scenario. Recommendations, SVP!
3. A sophisticated setup would also provide to give Red signals and/or effect dead track blocks for the two collision conditions [noted in the bracketed comment above]. Recommendations/suggestions, here?
Thanks for your time and attention--and, hopefully, your comments.
Malcolm Stewart
Malcolm G. Stewart is offline   Reply With Quote
Old 03-26-2008, 06:19 PM   #2 (permalink)
kpolak
Default
Welcome Malcolm!
Try these giz: Z-Stuff for Trains They make quite a few gizemos for trains!
Stop buy the Caboose for some informal chit-chat, and get to know some of the other members: Come on back to the caboose and get a cup of coffee [or sweet ice tea] Part V
Kurt
__________________
Kurt Polak
O-Gauge Ann Arbor, Michigan
kpolak is offline   Reply With Quote
Old 03-27-2008, 02:17 PM   #3 (permalink)
Malcolm G. Stewart
mgstewart
Kurt,
Thanks for the reference. However, I can't get any response when I seek it--can you provide a URL for the site?
Thanks again,
Malcolm
Old 03-27-2008, 09:33 PM   #4 (permalink)
kpolak
Default
Malcolm,
Just click on the underlined blue type, and it will open a new window for you, or z-stuff.net
De nada
Kurt
__________________
Kurt Polak
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
signals... NCMRailroad General Talk 2 10-15-2006 10:13 PM
Warning warning Will Robinson! note.boy Archives 11 09-03-2005 06:02 AM
CTI & Signals nolatron Technical Q & A 2 02-22-2005 07:43 AM
signals vbrr Technical Q & A 3 02-17-2004 11:45 AM
Hand Signals on the NYC/Big Four Roger Hensley The Real Thing- USA 0 04-25-2002 12:52 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
