HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > The Gauge - Model Trains > Technical Info > Technical Q & A
Reply
Thread Tools Display Modes
Old 03-27-2008, 11:41 AM   #1 (permalink)
yellowlynn
Default Slip switch?
I have a double switch (?), crossover switch (?), or slip switch, which it says on the back. Does anyone know anything about them?
I can figure it out, but if I installed it, I would immediately forget about how to work it. Does it have any value? And is anyone interested?
This should probably go in the sell or trade but I don't know enough about it.
Lynn
__________________
lynn
yellowlynn is offline   Reply With Quote
Old 03-27-2008, 12:01 PM   #2 (permalink)
Default
Lynn, double slip switches were used mostly in passenger yards where they had a lot of complicated track work. The slip switches took up a lot less space than conventional switches.
Russ Bellinis is offline   Reply With Quote
Old 03-27-2008, 12:29 PM   #3 (permalink)
TruckLover
BNSF and UP all the way!!
TruckLover's Avatar
Default
I would buy it from you Lynn but its Code 100 track (black ties) and I only use Code 83 track (brown ties)
__________________
Josh M.
Trucklover's Layout Index Thread
TruckLover is offline   Reply With Quote
Old 03-27-2008, 09:29 PM   #4 (permalink)
baldwinjl
Default
Double slips applied:
http://upload.wikimedia.org/wikipedi...ch_central.jpg
baldwinjl is offline   Reply With Quote
Old 03-27-2008, 09:57 PM   #5 (permalink)
60103
Pooh Bah
60103's Avatar
Default
Lynn: what you have is a single slip switch, as best I can see from the photos. You can only go around the left side of the crossing, while a doupble slip lets you go around both sides.
Single slips were uncommon in North America, but very common in Britain. They had a phobia about facing point switches (ones that would be approached from the point end) in passenger operations. On double track lines, a station would have a small yard on one side of the line. On one side there would be a switch located so the goods (freight) train could back in. The other direction would be set up with a switch and a crossing to get to the yard. The crossing would usually be a single slip, set so that it made a trailing crossover but trains going forward couldn't be re-routed by it. (Long winded explanation with no diagrams!)
__________________
David
NMRA #010887; NARA #79
Perth & Exeter Railway Company
Esquesing & Chinguacousy Radial Railway
60103 is offline   Reply With Quote
Old 03-28-2008, 11:03 AM   #6 (permalink)
yellowlynn
Default single/double slip
From what I understand now, this must be a double slip because it can curve right/left, or go straight thru from all directions.
It is too complicated for me, If anyone knows any kind of value I will put it in sale/rtrade column.
Thanks for the info
Lynn
__________________
lynn
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Slip Resistant Ruler PaperEngTech Tools of the trade 4 12-05-2005 10:49 AM
wiring an electrofrog double slip? dhutch Technical Q & A 4 12-24-2004 05:52 AM
Peco double slip coachsig Technical Q & A 1 02-11-2004 10:33 PM
Double slip? cidchase Technical Q & A 9 06-15-2002 12:29 AM
Double vs single slip billk Technical Q & A 9 11-21-2001 06:49 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
