HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Specific Model Categories > Armor and Military Vehicles
Support our community and these ads go away.
Reply
Thread Tools Display Modes
Old 04-02-2008, 08:54 PM   #16 (permalink)
Fishcarver
Card Models Moderator
Fishcarver's Avatar
Default
Ken:
Looking very good so far!
Jim
__________________
HOWE'S LAW:
"Every man has a scheme that will not work."
www.namaycush.com
Fishcarver is offline   Reply With Quote
Old 04-03-2008, 12:17 AM   #17 (permalink)
HeavyKevie
HeavyKevie's Avatar
Default
Very nice build so far - great subject! - one you don't see too often. I'm anxious to see how the compound curves work out on the turret assembly.
As far as being color blind you are not alone there...you may want to consider Johnny's solution for matching colors. Just take your book into a paint store and have them scan it with their color matching system, for a couple of bucks you can get a quart of paint that's an exact match... more than enough paint to do this and the dragon wagon about a thousand times over.
__________________
Trifles make perfection, and perfection is no trifle. -Michelangelo
HeavyKevie is offline   Reply With Quote
Old 05-14-2008, 11:24 AM   #18 (permalink)
kenlwest
Default
Hello everyone!
Just a quick note to let you know that I almost have the tracks built and added to the model. Hopefully this weekend I will post the pictures.
Other priorities are getting in the way.
Ken
kenlwest is offline   Reply With Quote
Old 05-15-2008, 08:59 PM   #19 (permalink)
kenlwest
Default
I just finished building and installing the tracks on the Sherman. This was about the most tedious and time consuming thing I think I ever did!.
The basic tracks are comprised of 2 strips that are glued together; print side out. Then the cleats are glued to the outside, and multitudes of track guides are glued to the inside. (see the pile of them)
The second picture illustrates the brutal tedium involved...
Then the track is fed over the top rollers and drive cog, then joined at the ends. Several of the track guides were pulled loose in the process and had to be reattached.
Not a perfect job by a longshot, but I am satisfied with the outcome. The rest of the tank should be a breeze!
Ken
Old 05-15-2008, 09:08 PM   #20 (permalink)
kenlwest
Default
Another picture (side view).....
Old 05-15-2008, 09:30 PM   #21 (permalink)
charliec
charliec's Avatar
Default
The GPM tracks aren't very realistic - but you've managed to do a great job with them. Most WW2 US tanks used a rubber block track (M4 Sherman Tank) which aren't easy to model in card. You might like to look at the Gremir M3 builds over at papermodelers.com for another take on US tank tracks.
Regards,
Charlie
charliec is offline   Reply With Quote
Old 05-15-2008, 11:34 PM   #22 (permalink)
Mark_1984
Moderators are people too
Mark_1984's Avatar
Default
Great job - It's the tracks that put me off doing a tank. I just wouldn't have the patience to cut out so many identical parts. Yours look very realistic.
__________________
Cheers
Mark
Free Model 3 Competition entry http://forum.zealot.com/t156826/#post799486
Mark_1984 is online now   Reply With Quote
Old 05-16-2008, 12:05 AM   #23 (permalink)
Soaring
Middle School Student
Soaring's Avatar
Default
Wow, that Sherman you have there looks excellent! The Tracks especially, I can't wait to see the rest of this Sherman
__________________
-Don't hold me up now, I can stand my own ground, I don't need your help now, you will let me down, down, down...- Rise Against: Prayer of the Refugee
Soaring is offline   Reply With Quote
Old 05-16-2008, 01:15 AM   #24 (permalink)
lriera
Default
I agree, the tracks are the WORST part of any tank (or tracked vehicle). But you have done an outstanding work.
I hope to see more soon. Thank you.
__________________
Lluis Riera
Finished: Willys Jeep from Modelik.
Finished: Kettenkrad Sd kfz 2 NSU from Modelik.
lriera is offline   Reply With Quote
Old 05-17-2008, 01:37 AM   #25 (permalink)
HeavyKevie
HeavyKevie's Avatar
Default
Quote:
Quote:
I could not agree with the two of you more... They are a true test of ones patients. Very well done
__________________
Old 05-17-2008, 01:09 PM   #26 (permalink)
Patty
King of Swaziland
Patty's Avatar
Default
WOW!!! This is looking NICE. I hope the rest of build is as fast and easy as this part.
__________________
Come on, you KNOW luft' 46 only happened to annoy rivet counters.
Patty is offline   Reply With Quote
Old 05-17-2008, 02:58 PM   #27 (permalink)
Stev0
Stev0's Avatar
Default
So far I have seen countless armor threads die at the track stage.
Good to see that you have pressed on.
As to the off color edging... You think 'brown' or 'tank' ink to those green areas would turn them down?
__________________
Download my projects today R5Unit EG-6 Droid Stubby Z34 Speedy Buggy
If I find these files or a printed version on eBay, I personally will rip the seller's *censored* - Anonymous
Stev0 is offline   Reply With Quote
Old 05-18-2008, 08:19 AM   #28 (permalink)
kenlwest
Default
To all,
Thanks for the encouragement! I finished some of the front ornaments and their metal guards. These are the time-consuming details, but also the most fun.
Note that I tried to tone-down the edges a bit by using OD green paint. Still not exact, but a lot better. I have a plastic model of an American WWII tank, and the instructions call for Olive Drab. This model is something a little different - can't quite figure it out.
Ken
Old 05-18-2008, 09:58 AM   #29 (permalink)
logicman
Greybeard
logicman's Avatar
Default
Nice build.
You have a lot of patience.
As for the colors, I like them. On my monitor this lot shows as brown with a green highlight to edges. That's the sort of thing a museum of engineering might do, to emphasise the working components. Red is more common, especially on cutaways, but for me, those colors suit the model.
__________________
Relax, it's just an opinion.
Stay safe - get site safety ratings >
http://www.mywot.com/
http://www.siteadvisor.com/
logicman is offline   Reply With Quote
Old 05-18-2008, 12:24 PM   #30 (permalink)
Stev0
Stev0's Avatar
Default
It's funny because I am building Nobi's Cromwell and it's roughly the same color base as your overall sherman and the edge coloring is the exact same.
The turret is going to be interesting. I want to get this kit.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
PTA 1/72 scale M4 Sherman tank.... nebeltex Armor and Military Vehicles 30 05-05-2007 12:45 AM
M4A3 Sherman GPM version 2001 help maybaygiay Armor and Military Vehicles 6 04-27-2007 10:13 PM
Sherman paper warrior Dream kits and wish list 1 12-01-2006 05:25 PM
Free Sherman? TigerMike Armor and Military Vehicles 4 01-26-2006 08:50 PM
M4 Sherman Tank gman95687 Armor and Military Vehicles 1 10-27-2005 11:13 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
