HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Members > Forum Help
Reply
Thread Tools Display Modes
Old 03-30-2008, 03:58 PM   #1 (permalink)
Dragos
Dragos's Avatar
Default Exporting unfolded surfaces - help
Hello,
Anyone knows how to export the unfolded surfaces from Rhino. I know the Export option , but there is no viewable format (jpeg, gif, png, and so on) .
I must export them as a dwf file and then convert it into a pdf? Any ideea?
And one other question: How can I scale the models in Rhino?
__________________
Est modus in rebus.
My Blog
Dragos Cardmodels
Dragos is offline   Reply With Quote
Old 03-30-2008, 04:23 PM   #2 (permalink)
Lex
Dollmaker
Card Models Moderator
Lex's Avatar
Default
I always use .ai, which can be opened with a vector program like Illustrator ^^, the vector program can then convert the file into a bitmap
P: The "Scale" button is located in the Transformations set of commands lower down the toolbox, and you can also type in "scale" or "scale3d" etc in the command line You can either scale by typing the scale factor, or use reference points
Lex is offline   Reply With Quote
Old 03-31-2008, 06:16 PM   #3 (permalink)
Bernhard
Bernhard's Avatar
Default
Try the following:
Select the unrolled parts in Rhino3D.
Use the "export selected" option.
Choose "Windows metafile" (.wmf) as the file format.
Now you should be able to view your unrolled surfaces in Windows Picture And Fax Viewer for example. Many other applications can also handle wmf files.
Good luck
Bernhard
Bernhard is offline   Reply With Quote
Old 04-01-2008, 09:22 PM   #4 (permalink)
SteveM
Default
Quote:
Originally Posted by Bernhard View Post
Try the following:
Good luck
Bernhard
Paint Shop Pro will read wmf and maintain them as vectors. Will also maintain the color which if I remember correctly is lost in the ai format. Only problem is that curves are not exported as curve vectors (circles, arcs, or beziers) but instead as millions of short "lineto"s.
__________________
http://www.HomespunMagixx.com
SteveM is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rounded surfaces Arjun Tips and Techniques 14 12-09-2007 10:08 AM
Transparent surfaces Arjun Tips and Techniques 12 12-09-2007 01:49 AM
Exporting model with textures from 3d max not showing up CrimosnBronxs Software in Cardmodeling 5 11-03-2007 12:46 AM
unfolded models in 3d software lolson Designer's Corner 1 06-07-2007 04:13 AM
exporting canadian collectors coins Roland Watson Archives 4 08-18-2005 06:01 AM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
