HobbiesHobby ForumHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > The Gauge - Model Trains > New Model Railroaders > The Caboose
Support our community and these ads go away.
Reply
Thread Tools Display Modes
Old 04-09-2008, 07:50 PM   #1 (permalink)
earlybirdtrain
Junior Member
earlybirdtrain's Avatar
Default Just Questions
Is it possible to change the couplers on a car or train from moose horn? couplers to knuckle couplers?
__________________
I Model in HO -- AJ
earlybirdtrain is offline   Reply With Quote
Old 04-09-2008, 07:53 PM   #2 (permalink)
TruckLover
BNSF and UP all the way!!
TruckLover's Avatar
Default
Quote:
Sure it is, simply unscrew or pop off the coupler cover and slip in a new Kadee knuckle coupler or whichever you prefer. i stick with the Kadee #5 coupler for all my HO rolling stock and engines
__________________
Josh M.
Trucklover's Layout Index Thread
TruckLover is offline   Reply With Quote
Old 04-09-2008, 07:59 PM   #3 (permalink)
RonP
Member of the WMRC
Default
If you can't get it take a clear picture of it and we can come up with a plan.
Josh's advice on couplers is the best IMHO
__________________
Come visit the fastest growing Model Railroading Emagazine @ Scratchbuilders Guild
Subscribe today (it's free)
RonP is offline   Reply With Quote
Old 04-12-2008, 07:05 PM   #4 (permalink)
earlybirdtrain
Junior Member
Default
what do you mean by this
__________________
I Model in HO -- AJ
Old 04-12-2008, 07:10 PM   #5 (permalink)
earlybirdtrain
Junior Member
Default
ok here is a pic
__________________
I Model in HO -- AJ
Old 04-12-2008, 07:11 PM   #6 (permalink)
earlybirdtrain
Junior Member
Default
here is another
__________________
I Model in HO -- AJ
Old 04-12-2008, 07:38 PM   #7 (permalink)
RonP
Member of the WMRC
Default
IMHO mean in my humble opinion.
And yes those pictures are what is needed. Someone will come along and tell you what you need to know very shortly, I am sure.
That doesn't look like a screw, is it a plastic post ? Maybe there is a kadee specific piece to work with this. To get that out isn't all that hard.
__________________
Old 04-12-2008, 07:44 PM   #8 (permalink)
earlybirdtrain
Junior Member
Default
i know it is not that hard to take the actual coupler out, because i have done that SOO many times!
__________________
I Model in HO -- AJ
Old 04-12-2008, 08:15 PM   #9 (permalink)
slekjr
slekjr's Avatar
Default
Dear AJ
I have cut the couplers from the trucks and used kadee #5s and body mounted them. If you do the car takes a larger minimum radius curve, and sometimes you have to adjust the center pin socket to get the correct coupler height. You might be able to use one of the other knuckle style plastic couplers as a direct replacement, or if you are only trying to make them look closer to prototype you can actually trim the horn hooks to look more like a knuckle. (this is the cheapest way out.) If you are careful it will actually couple to a kadee coupler, although they won't uncouple as easily.
Charlie
slekjr is online now   Reply With Quote
Old 04-12-2008, 10:25 PM   #10 (permalink)
eightyeightfan1
Now I'm AMP'd
The Gauge Moderator
eightyeightfan1's Avatar
Default
Kadee also makes conversion kits to change from the truck mounted horn-hook couplers. You have to know the manufacturer of the trucks, to get the right kit. Walther's catalog has a conversion chart and you can also get it at Kadee's sight.
__________________
(Ed)itor Gauge E-Mag
NARA member #78
I went to my HAPPY PLACE, but it was closed for renovations......
Gauge E-Mag:http://www.zealot.com/files/magazine/jul08/jul08.htm
eightyeightfan1 is online now   Reply With Quote
Old 04-13-2008, 02:40 PM   #11 (permalink)
earlybirdtrain
Junior Member
Default
how much do kadee couplers cost?
__________________
I Model in HO -- AJ
Old 04-15-2008, 09:08 PM   #12 (permalink)
earlybirdtrain
Junior Member
Default
and wat type of couplers do lionel trains have???
__________________
I Model in HO -- AJ
Old 04-15-2008, 09:54 PM   #13 (permalink)
60103
Pooh Bah
60103's Avatar
Default
Early Bird: Lionel HO had the hook-horn or NMRA couplers like your pictures. Lionel O has their own make.
Truck mounted couplers are the hardest to change to Kadees because they're usually not designed to be replaceable, even if they break. Kadee make a #9 which has a smaller screw hole, but is otherwise like the #5. You might fit something in by trimming bits off the truck that hold the coupler.
I've been paying about $4.50 for 2 pairs of couplers, although one shop wants about $6.50 for them. (in Canada). #5s often sell for less in bulk or on sale.
__________________
David
NMRA #010887; NARA #79
Perth & Exeter Railway Company
Esquesing & Chinguacousy Radial Railway
60103 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
questions brianthehawaiian RC General 0 03-03-2007 11:43 PM
Help!!! 3 Questions TheYardBoss Technical Q & A 3 03-10-2006 06:27 PM
DWI questions TC Archives 53 05-13-2005 05:01 PM
Questions from the new guy. mortarman General Talk 8 03-29-2005 09:03 AM
2 Questions Tyson Rayles Technical Q & A 10 05-04-2003 10:25 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
Powered by vbWiki Pro 1.3 RC5. Copyright ©2006-2007, NuHit, LLC
