HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > The Gauge - Model Trains > New Model Railroaders > Photography, Books, Video, Scenery
Reply
Thread Tools Display Modes
Old 04-11-2008, 03:28 PM   #16 (permalink)
viperman
Default
galt, the St Jacobs actually looks to be pretty much what I would like to have with my layout (or future layouts). Excellent scenery. And the trains don't completely dominate it like on a lot of layouts, its more realistic in that the trains run through the scenery. THAT is my goal
__________________
Steven
http://forum.zealot.com/t112267/
viperman is offline   Reply With Quote
Old 04-14-2008, 12:27 PM   #17 (permalink)
galt904
Default
Hey Chris, how old is the stairs to the upper level by the entrance door (that puts you in the Mckerrow area on the 2nd level)? I got to thinking, and I don't remember it being there before...
__________________
Chad - galt904
galt904 is offline   Reply With Quote
Old 04-14-2008, 05:12 PM   #18 (permalink)
acsoosub
acsoosub's Avatar
Default
Chad,
That part is actually some of the older construction on the current layout.
Years ago, the club had a smaller layout in part of a warehouse somewhere in Kitchener (Boehmer Box factory). Eventually they were forced to move and settled in our present location.
As I understand it, the only parts of the old layout that were incorporated into the new one were a few pieces of Sudbury yard ladder (some of the switches were changes and a couple more tracks added, and the whole thing lengthened by at least 4 feet) and the helix used to go from Nairn to McKerrow (and to the lumber mill on the level below Nairn). There's also some pieces from an old scene at Levack from the old layout stored upstairs, but these aren't likely to be reused.
The earliest construction was building/re-arranging some walls to form the front lounge/office area, and installation of Sudbury yard. Early on, there was a single level, double-ended staging yard that connected both ends of Sudbury.
The branch line from Sudbury to Mckerrow was built just under 10 years ago from about 1998-2000. Also the maintenance facilities and the secondary yard behind the shops were probably started around this time frame as well. Although, finishing all the switches in the car shops area somehow lost priority in the following years, something we hope to get back to sometime, considering the central nature of Sudbury to the layout.
The levels below Nairn, with the lumber mill and nickel mine spurs were added a little later.
Following getting the branchline in service, the simple staging yard across the bottom was replaced by the current double level staging yard, which connects via helix to the east end of Sudbury. This was built over a few years. Based on construction photos at the club, I gather they only built the helix up high enough to connect directly to Sudbury at first, and later finished it off all the way up to Romford with the double track helix back down to Sudbury. This is what it basically looks like now:
http://www.wrmrc.ca/graphics/romford-helix1.jpg
To the casual viewer, this arrangement doesn't really seem to make sense, until you image that a complete scene with a full wye junction will be here, with one leg running down to the staging yard, one running down to Sudbury, and one continuing in the visible scene towards the camera, towards North Bay and Montreal. The track from the west end of Sudbury yard towards Cartier and western Canada wraps around the outside of the helix and just kindof stops, requiring us to use the hidden ramp as serial staging (fits 4 trains of 40-50 cars on two tracks) - not the most flexible operationally. The plan is to have this continue on and emerge into the scene next to and above west sudbury by next year, and eventually upstairs to a temporary full staging yard. This is next on our construction agenda for this summer.
All of the above was basically in place when I joined the club about 3-4 years ago. However a lot of work has been done in the staging yard to add a proper control panel, optical occupancy detectors, etc. There is a scary amount of electronic bits installed there, which took a long time to complete and will never be seen by vistors.
Over the last year or so, we have completely rewired the yard, adding feeders to eliminate dead spots and engine stalling, disconnecting feeders from existing feeder buses and adding new ones to completely isolate sections of the layout (the original wiring was all cross-connected, so the layout operated as a single block, which is bad when a minor derailment causing a minor short circuit shuts down _everything_) and we also started rewiring and blocking the mainline tracks for occupancy detectors and signalling. Also on the agenda: ABS signalling from Sudbury to Romford, the interlocked junction at Romford, and CTC on pretty much the rest of the mainline part of the layout. The branchline to Nairn, McKerrow, Sault Ste. Marie remains "dark territory." In the 1970s it would have been operated by timetable and train orders. We run it as OCS right now, as it's a little easier to manage, especially with hand-held or headset radios.
Also over the last year, we built all the stuff in the previously empty space in the middle of the layout. (New stairs, new walkway, new ceiling, new helix, new benchwork in the middle and down the staging yard side, new lighting) It used to store extra wood and miscellaneous junk. (And in a way still does, since we shoved everything in there out of the way for the tour) This is where we are doing the most construction work right now, and we are still finishing up the mainline wiring. (a few things were temporarily reconnected to work for the tour).
So, yeah, I think that pretty much provides a synopsis of the layout's history at the current location...
We've got a ways to go but it should be pretty cool as it takes shape. Looking at the plan drawings and some of the current construction can be a little confusing, but the overall plan actually make sense and is pretty neat. Starting in Sudbury, there are three directions you can take, each matching up to a line or direction from Sudbury on the real railway. One set of aisles go towards Sault Ste. Marie and Manitoulin Island. One set goes west towards Cartier, and one goes east towards North Bay. A no point other than Sudbury do these aisles ever reconnect. So if you're at the end of the aisle at Cartier (west end of the layout), to get to Sturgeon Falls (east end) you might actually be physically 5-10 feet away, but the only way to get there is to go all the way around through Sudbury.
Hidden trackage serves to lengthen the run between stations. The member who designed the plan estimates the mainline length will end up being almost 20 scale miles. With a 4:1 fast clock for operation, that's about 100 miles which is pretty close to the real thing. So schedules and times can be pretty realistic. With meets, it could end up taking up to or over an hour to get a train from one end to another. We'll probably need a lot more operators then, as crews will be tied up running a particular train for much longer than the current 10 minutes start to stop for a mainline train running from staging to staging.
__________________
Chris van der Heide
Guelph, ON.
acsoosub is offline   Reply With Quote
Old 04-15-2008, 12:32 PM   #19 (permalink)
galt904
Default
Sounds pretty ambitious! How much of the Manitoulin Island trackage will be modelled? I'd assume this is going in the top most level? I think it ends at a wye right now around the Mckerrow station?
__________________
Chad - galt904
Old 04-15-2008, 05:43 PM   #20 (permalink)
acsoosub
acsoosub's Avatar
Default
Quote:
The wye at McKerrow is the start of the Little Current subdivision, and we will take it to Little Current/Turner. Right now it's just a temporary yard across the aisle from McKerrow, with a runaround track and a track for each location: Espanola, Lawson Quarry + Birch Island, Little Current + Turner Yard. Eventually the paper mill at Espanola will be located in that spot, but mainline construction is more of a priority right now.
__________________
Chris van der Heide
Guelph, ON.
Old 04-15-2008, 10:13 PM   #21 (permalink)
cntown
Default
Is there plans to built the Lafarge Cement plant ?
cntown is offline   Reply With Quote
Old 04-16-2008, 12:09 PM   #22 (permalink)
acsoosub
acsoosub's Avatar
Default
If you mean the dock and silos on the lake at Moorey, yes. (it's Canada Cement in the 1970s).
__________________
Chris van der Heide
Guelph, ON.
Old 04-16-2008, 06:50 PM   #23 (permalink)
cntown
Default
I worked for a Transformer repair company at the plant one summer and also travelled up and down to Little Current for another trucking company as well as between the "Bay" and the Soo. That area has some of the nicest scenery in Ontario. When does your club have its open house next?
Old 05-04-2008, 05:53 PM   #24 (permalink)
acsoosub
acsoosub's Avatar
Default
Our next official open house will be in October, after Thanksgiving. We're not really doing anything on the Little Current subdivision section right now, we're concentrating our efforts on the Cartier subdivision mainline heading out in either direction from Sudbury, and we should have some more to show on that front by the fall.
__________________
Chris van der Heide
Guelph, ON.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
DoubleHeaders Tour this Saturday April 5 galt904 Upcoming MRR Events Forum 5 04-04-2008 09:41 PM
2008 MTH vol 1 ozzy G / O / S Scale Model Trains 19 01-03-2008 02:57 PM
What do we hope to see in 2008??? Wildcatfootball HO Scale Model Trains 19 12-21-2007 05:24 PM
Anyone have SW Ontario Double Headers tour pictures? galt904 General Talk 7 04-06-2007 05:04 PM
My Doubleheaders tour 2006 pics galt904 Photography, Books, Video, Scenery 15 04-19-2006 03:36 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
