HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Card Models > Card Modeling
Support our community and these ads go away.
Reply
Thread Tools Display Modes
Old 04-13-2008, 12:03 AM   #1 (permalink)
MikeBer
MikeBer's Avatar
Default Hull framework elements
I have purchased the Modelik COURBET French battleship and will start building in the next few weeks. As a newbie to card modelling, I was wondering if anyone has used 1mm balsa sheet for hull framework elements instead of laminating to card?
Is this a feasible idea?
MikeBer is offline   Reply With Quote
Old 04-13-2008, 12:11 AM   #2 (permalink)
cgutzmer
Reserves Librarian
Card Models Administrator
cgutzmer's Avatar
Default
hmmm, its a good question. I would be hesitant given the grain in the balsa - I think it snaps kinda easy. if you laminate even a piece of palin old paper to it though it might prevent that! it would most liekly be easier to cut than 1mm card.... give it a try (with a scanned part for safety) and let us know!
Chris
__________________
Looking for models - try the Zealot WIKI! Click here -> http://wiki.zealot.com/index.php/Free_Models
cgutzmer is offline   Reply With Quote
Old 04-13-2008, 02:10 AM   #3 (permalink)
David H
David H's Avatar
Default
I came to card modelling via-balsa free flight.
One issue I had with balsa was it is a very variable material. No matter how careful I was in selecting sheet I found that all but the most expensive indoor materials had hard or soft edges.
Try looking through your household and / or office recycling box for different types of card. I have often found perfect materials for formers lurking there!
The card backing for shirts is a good option, 1mm thick but with an open structure that is easy to cut. The backs of note pads and jotters is another fine source.
Experience has taught me that I have to select to an accuracy of considerably less than 0.5mm! The odd 0.1mm here and there is OK but not much thicker or thinner or trouble follows close behind. In short get some callipers to assist in scavenging.
(I sound like some sort recycling nut, suppose I am!)
D
David H is offline   Reply With Quote
Old 04-13-2008, 08:02 PM   #4 (permalink)
jaffro
Card Modelerator
Card Models Moderator
jaffro's Avatar
Default
It's funny you should mention that... Today I am going to go out and price some balsa as I'm becoming less and less satisfied with the mess I'm making of my Daring hull. I'm thinking if I start with a good sturdy balsa hull, the cardstock structure above won't warp (my cardstock hull has started to twist a little).
This is not to say a perfect Hull can't be achieved in card, just not by me.
If the balsa is affordable I'll update my thread and let you know the results.
David: As far as recycling goes, I've just started working for a large retail outlet that see's hundreds of pallets of stock come and go on a daily basis, I'm starting to notice a lot of VERY decent cardstock used to protect the stock in transit and am in the process of starting a collection.
__________________
Current Builds:The Daring Project / Batman Begins Tumbler Just Finished: Mad Max Interceptor
Got a question? Got some advice to share? Check out the WIKI
jaffro is offline   Reply With Quote
Old 04-14-2008, 11:04 AM   #5 (permalink)
MikeBer
MikeBer's Avatar
Default
Hi Jaffro,
I checked out 1mm balsa today and boy is it fragile! I am going to stick with card stock but am going to notch out the frames where they meet the centre vertical keel piece and put a wood stringer in each side of the keel piece to keep it straight lengthwise. I will be starting the build hopefully this week and will post pics. Le Courbet French battle cruiser from Modelik
Old 04-17-2008, 12:09 AM   #6 (permalink)
sakrison
sakrison's Avatar
Default
I know it's been done--I remember seeing a thread here or on a previous forum about balsa formers for hulls. Personally, I'm sticking with heavy (1-2mm) card (sometimes called "paper board"). Cut, assembled and sealed with dullcoat spray, it should be a lot stronger and more stable than most balsa.
__________________
sakrison@charter.net / www.ChasingtheGhostBirds.com
"Imagination is more important than knowledge."- Albert Einstein
Current Projects: RR Merlin 45 engine @ 1:16.5 scale
and 1/72 U-Boat Type VII
sakrison is offline   Reply With Quote
Old 04-20-2008, 12:07 AM   #7 (permalink)
jaffro
Card Modelerator
jaffro's Avatar
Default
Mike, I checked out some 1mm balsa myself, the day I replied to your post and you're right, it's flimsy... way too flimsy.
the 1.5mm to 2.5mm stuff didn't seem too bad, but it's really not a huge improvement on what can be achieved with cardstock. I've decided to stick with the cardstock and start scrounging from work for whatever I can get my hands on.
If I can't find the right stuff, it's still cheaper to buy sheets of heavy cardstock than a decent strength/thickness of balsa so I think i'll just stick with "the good stuff".
__________________
Old 05-14-2008, 10:23 AM   #8 (permalink)
cdavenport
cdavenport's Avatar
Default
I realized too late that I posted this in the wrong thread. I hope that the information will be useful to you and other modelers.
Here is the fix to eliminate any warpage in any model; follow the link and purchase a large sheet of Letraset 2000 mechanical board. It just happens to be 1mm thick. If you need thinner board, just delaminate what you need.
[url="http://www.dickblick.com/zz134/03/"]
This board is dimensionally stable. I have a supply that I have been carrying around the world for over 20 years and it has still not warped a bit. I had my supply stored in a room that suffered some water leakage; the board in contact with water suffered while the rest remained undamaged.
It is more expensive than el cheapo cardboard, but when you consider no hassles, no headaches, it's a bargain. A large sheet will cost a bit over $7 plus shipping, more than enough for several models, depending on their size.
Check your local art store. You'll save the shipping cost.
__________________
Major CT Davenport, USAF, (Ret)
Teacher, Carver Middle School
cdavenport is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Layout Design Elements for industrial belt lines jetrock Track Planning 6 02-22-2006 07:56 PM
Nitro Elements Art Attack Nitro Snowmobile almost rcnut RC Cars Buy & Sell Forum 3 10-13-2005 10:58 PM
Lauan ply framework construction ocalicreek Technical Q & A 4 06-28-2005 12:21 AM
Want: Pacific Exhibit #216 Hull/Hull hockeymatrix Archives 0 04-10-2005 05:13 AM
Weathering the Elements Railery General Talk 1 12-07-2002 07:19 AM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
