HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > The Gauge - Model Trains > Technical Info > Technical Q & A
Reply
Thread Tools Display Modes
Old 04-13-2008, 08:27 PM   #1 (permalink)
Relic
Relic's Avatar
Default sa mokin'
I could have called it "outa luck"
Bought a Kato RSC3 at a show on the weekend,all my engines {10} are from shows and I;ve had good luck,they all seem to run pretty well,till now.
Put it on the layout,by itself,and it made about two laps{about 55 ft} then started to slow down,went another 5 feet an started to smoke.Now it goes real slow forward but seems pretty much normal in reverse.{bearing in mind I've never seen a new engine run}
Oh yeah I run it DC,the guy that sold it said it was DC,it does have directional lighting.
What fried,can it be fixed{easily}and is it worth it.
thanks ahead of time
__________________
poverty is the mother of invention
Relic is offline   Reply With Quote
Old 04-14-2008, 03:34 PM   #2 (permalink)
MasonJar
It's not rocket surgery
The Gauge Moderator
MasonJar's Avatar
Default
I'd take the cover off right away (no more running...!) and see what happened. Best case, some insulation has melted off a wire, with no other damage. Worst case - you've let some smoke out of the electronics. Lots of possibilities in between...!
If it still moves, my first thought would be lubrication is required, or perhaps there's something jammed in there (muight account for the difference in back/forward performance). If it dried out, you'd get slowing, but if things still turn fast enough, you might get smoke. However, you may have damaged gearing which would require a fix. If it is something just stuck in there, then take it out, but carefully... Might be a part, or might be carpet fuzz...
Anyway, I think that a look inside is in order before you do anything else. If it's not obvious what happened, get back to us.
Andrew
__________________
Check out The Gauge's Modular Layout Forum
Questions? Visit The Academy at The Gauge for all kinds of How-To's
Planning a layout? Try the Givens and Druthers form
MasonJar is offline   Reply With Quote
Old 04-14-2008, 07:34 PM   #3 (permalink)
ezdays
Out AZ way
The Gauge Administrator
ezdays's Avatar
Default
I'd tend to say that if it was the motor winding, it wouldn't run at all. Like Andrew says, it could be a short of some sort, but definitely, a good cleaning is probably in order.
__________________
Don (EZ) Day
Administrator and
Railroad tycoon
NARA #88
Hey, it's us
ezdays is offline   Reply With Quote
Old 04-17-2008, 02:05 PM   #4 (permalink)
Relic
Relic's Avatar
Default
thanks fellas,I took it apart right away to check for melted wires{ there were none} I ran it a bit with the hood off, same thing slow forward, fast reverse .I'll have to wait 'till I go to town again to get some proper lube.
This Kato is wired a bit different than the rest of my"fleet"
I'll cypher it out ,thanks again
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
