HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > The Gauge - Model Trains > Model Railroading > Scratchin' & Bashin'
Reply
Thread Tools Display Modes
Old 04-14-2008, 06:56 PM   #1 (permalink)
bobbyspfan
Junior Member
Default Cleaning Corroded Brass
I did some work on an unpainted Cary SW1500 body some years and installed the brass handrail set. I put the unit away unpainted. I recently got it out to start working on again and noticed the brass handrail and stanchions have some corrosion (green and white powdering). Does anyone know with what the corrosion can be removed and if it would still be salvageable? Thx in advance.
bobbyspfan is offline   Reply With Quote
Old 04-14-2008, 07:14 PM   #2 (permalink)
nachoman
nachoman's Avatar
Default
My guess is the corrosion is some kind of reaction between the solder flux and the brass. Did you use acid core solder or acid flux used for pipe sweating?
Try cleaning it using mild dish detergent and water. Sometimes I take an old toothbrush and use it to scrub with. If you suspect acid residue, you can neutralize the acid using baking soda and water. Hopfully the corrosion is only surficial, in which case once it is removed, the locomotive can be painted as usual.
Kevin
nachoman is online now   Reply With Quote
Old 04-14-2008, 07:15 PM   #3 (permalink)
steamhead
steamhead's Avatar
Default
Hi...You might try this....
Homemade Brass Cleaner
Good luck...!!
__________________
Gus (LC&P).
steamhead is offline   Reply With Quote
Old 04-14-2008, 07:51 PM   #4 (permalink)
RonP
Member of the WMRC
Default
Good luck...!!
That is a good link however he can't dip his loco in ketchup. After reading a few of those I'd deduct that tomato juice vineger and salt is a good cleaner. That or hot sauce...
__________________
Model Railroad, how to E-mag come and visit us @ Scratchbuilders Guild
RonP is offline   Reply With Quote
Old 04-14-2008, 10:04 PM   #5 (permalink)
60103
Pooh Bah
60103's Avatar
Default
I might try Vinegar with salt in it. If you have an old penny or another bit of green copper, test on that.
__________________
David
NMRA #010887; NARA #79
Perth & Exeter Railway Company
Esquesing & Chinguacousy Radial Railway
60103 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
cleaning brass track cjfeltner Technical Q & A 14 05-08-2007 09:40 PM
Athearn - Brass Bearings - cleaning? Gary S. Technical Q & A 7 04-15-2007 05:16 PM
cleaning up King Bonk The Caboose 1 09-11-2006 09:52 PM
Track Cleaning Car frac HO Scale Model Trains 4 05-17-2006 11:36 PM
Cleaning? rockislandmike Technical Q & A 8 06-11-2002 10:22 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
