HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > The Gauge - Model Trains > Technical Info > Technical Q & A
Reply
Thread Tools Display Modes
Old 04-16-2008, 01:40 PM   #1 (permalink)
tetters
Rail Spiking Fool!
tetters's Avatar
Default Wiring two opposed turnouts and a 19 degree crossing.
Hey folks.
Maybe you can help me with this.
Sorry for the crappy MS Paint pic. The frogs are in black and I hope the gaps are clear enough (went back and marked them in orange). Green and Red are the colours that I chose for the track buss wiring. I am using Tortoise Machines to control the two t.o's.
There are six points, one for each t.o. and two pairs in the x-ing itself.
Am I correct in assuming that I should be able to use the secondary internal switch in the Tortoise to switch the polarity of the frogs on the crossing? Realistically, you'd only have one loco using the crossing at a time. So as long as ensure that both t.o's are wired so that the polarity is correct when they are thrown for that particular route then I should be good to go. Right?
Thanks...I do tend to over think these things way too much.
__________________
"Life is not a journey to the grave with intentions of arriving safely in a pretty well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming...
WOW! What a ride!" -Anonymous-
My Layout Progress.
http://forum.zealot.com/t115665/
Last edited by tetters; 04-16-2008 at 01:55 PM. Reason: cleaned up crappy MS Paint pic...still crappy...LOL
tetters is offline   Reply With Quote
Old 04-16-2008, 10:13 PM   #2 (permalink)
60103
Pooh Bah
60103's Avatar
Default
I think you could do it by having the crossing frogs wired to the turnout frog in the same rail (the one farther away). This will work as long as you don't have both turnouts curved at the same time.
__________________
David
NMRA #010887; NARA #79
Perth & Exeter Railway Company
Esquesing & Chinguacousy Radial Railway
60103 is offline   Reply With Quote
Old 04-17-2008, 09:13 AM   #3 (permalink)
tetters
Rail Spiking Fool!
tetters's Avatar
Default
Thanks David. I got it figured out last night. I must say I'm happier then a pig in shhhhh......well you get the idea. ( Waits for slap from mod... )
For the x-ing I wired up the it's points and t.o. points that are next to each other. This way when the t.o. is thrown to hit the crossing, the x-ing points are switched to green while the frog is switched to red. Meanwhile the opposite t.o. is left in the straight thru position, which means the x-ing points for it are switched to red. This allows the loco to roll right thru.
It actually all started to make sense after I drew up that little sketch. I think simplifying the track work into that basic sketch allowed me to see the solution. Looking at all the actual rails and trackwork just made it confusing.
__________________
My Layout Progress.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wiring Automatic Crossing for DCC Rusty Spike Technical Q & A 2 04-03-2007 04:05 PM
hard wiring crossing signals cagey G / O / S Scale Model Trains 3 10-02-2006 12:42 PM
How much additional wiring is really necessary for turnouts? 91rioja DCC Forum 22 07-24-2006 04:47 PM
Need help wiring turnouts Mannix DCC Forum 2 07-09-2006 10:52 PM
How to choose the correct crossing degree? Conrail Technical Q & A 4 09-21-2005 07:01 AM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
