HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Card Models > Card Modeling
Reply
Thread Tools Display Modes
Old 04-25-2008, 10:56 AM   #1 (permalink)
andrew ferguson
Default how to fix water damaged paper?
is there any way to smoothen out paper that has had a bit of water damage and has become wrinkled and puckered a bit as a result? I was thinking of running over it with an iron set on low, with a piece of cloth in between the iron and the paper but thought i'd ask here before trying it.
Any advice appreciated.
andrew ferguson is offline   Reply With Quote
Old 04-25-2008, 12:15 PM   #2 (permalink)
cgutzmer
Reserves Librarian
Card Models Administrator
cgutzmer's Avatar
Default
Sorry to hear that.... If that fails, try making it a bit moist again then ironing it out again. I dunno though. I have never done it!
Chris
__________________
Looking for models - try the Zealot WIKI! Click here -> http://wiki.zealot.com/index.php/Free_Models
cgutzmer is offline   Reply With Quote
Old 04-25-2008, 12:39 PM   #3 (permalink)
jagolden
jagolden's Avatar
Default
I'd suggest using a damp cloth under the iron.
I needed a $50 bill for gift card, could get a fresh one from the bank so I took the best one they could give me and ironed it.
Looked brand-spankin new!
jagolden is offline   Reply With Quote
Old 04-25-2008, 04:24 PM   #4 (permalink)
nebeltex
Card Models Moderator
nebeltex's Avatar
Default
while a "bill" can certainly seem paper, american currency is mostly linen. the ink never really dries (so they say, rub a bill on paper, some ink will transfer). that brings me to a second point. try it on an piece of similar paper with the same ink (if possible). you should be o.k. on a low setting, but you could "lift" ink to the cloth between.....
__________________
"ex tenebris lucem"
nebeltex is offline   Reply With Quote
Old 04-30-2008, 01:41 AM   #5 (permalink)
eric_son
eric_son's Avatar
Default
Sometimes, moisture will also 'expand' the paper a bit. So, even if you iron it out and get rid of most of the wrinkles, the paper might never revert to its original flat state.
__________________
I can't believe it's not plastic!
Cut, Fold & Paste (my builds, etc.)
eric_son is offline   Reply With Quote
Old 04-30-2008, 04:35 AM   #6 (permalink)
Lex
Dollmaker
Lex's Avatar
Default
Most paper has their fibres aligned in the long direction, and their lengths might change with moisture. So even if the model is ironed out, I'd still be expecting some misfitting parts from this anisotropic expansion... (In fact the heat of ironing usually makes things worse)
Lex is offline   Reply With Quote
Old 05-01-2008, 07:46 PM   #7 (permalink)
Stev0
Stev0's Avatar
Default
I had softcover books get saturated from rain one time. Without opening them or disturbing them, I took each and sandwiched the book between 2 larger sized planks and nailed the planks together VERY tightly. I hung them up and not only did it dry but any warpage that would have occurred from being wet never happened.
I don't know why the book and others like it did not turn into a block of solid goo.
That was about 15+ years ago and I still have the books in perfect condition.
The method above only works with newly wet items, however ironing may be a good idea for wrinkled items as long as you apply some steam to the pages. Pulpy paper may not work well with steam because it has a propensity to deform.
__________________
Download my projects today R5Unit EG-6 Droid Stubby Z34 Speedy Buggy
If I find these files or a printed version on eBay, I personally will rip the seller's *censored* - Anonymous
Stev0 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Damaged coins on eBay acaudle@gate.net Archives 14 10-16-2005 06:01 AM
Free - WW Damaged Stamps To Use In Artwork / Whatever! mohawky@charter.net Archives 2 05-14-2005 12:00 PM
Marshall's Courtroom Damaged ronrpk Archives 6 05-05-2005 10:00 AM
Any layouts that got damaged in the hurricanes? thebullroars HO Scale Model Trains 0 09-14-2004 09:48 PM
Engine damaged? vette_7t9 RC Engine Forum 7 05-21-2004 08:33 PM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
