HobbiesHobby ForumHobby WikiHobby Blogs
Zealot Hobby Forum
Go Back   Zealot Hobby Forum > Card Models > Specific Model Categories > Science Fiction Models
Reply
Thread Tools Display Modes
Old 05-08-2008, 03:24 PM   #16 (permalink)
xadow
Junior Member
Default
Thanks Tars and Gearz.
Tars: to achieve a smooth hull, I just followed this great tutorial http://www.forum.zealot.com/t143511/
Gearz: The base was a challenge especially the the two little antennas on top of the building, and tweezers, were absolutely essential.
I hope to have some more pictures for you guys, tomorrow.
xadow is offline   Reply With Quote
Old 05-11-2008, 10:39 PM   #17 (permalink)
foxmalcolm
-=3D Modeler=-
foxmalcolm's Avatar
Smile
Hey that looks cool.
All of my printers have died in the last 6 months and all I have to work with is an old cannon BJC-210sp printer.
So I couldn't get the fine print detail needed to make the little control tower and I ended up scratch building one from a drinking straw. Props to you for doing such a good job.
I like the little wire engine struts, did you follow a template or is each one custom made to fit?
__________________
"WOAH! Did you just see that?!"
"No! And neither did you!"
foxmalcolm is offline   Reply With Quote
Old 05-12-2008, 04:20 AM   #18 (permalink)
xadow
Junior Member
Default
Another week another piece. Today it's time for the gun ports and the lower detail.
Old 05-12-2008, 05:52 AM   #19 (permalink)
xadow
Junior Member
Default
Almost forgot, i also added the rudders
Old 05-14-2008, 09:37 AM   #20 (permalink)
Gearz
Gearz's Avatar
Default
Those fins look great xadow ~ definitely needs a sound effect now
set wav in zip to loop
__________________
SF Models
HOMEWORLD FREELANCER CRIMSON-SKIES SAAB BSG ST TTA TA MODEL-STANDS +
Gearz is offline   Reply With Quote
Old 05-20-2008, 09:24 AM   #21 (permalink)
xadow
Junior Member
Default
Gearz: That sound is perfect for the model. I think that i have an old mp3 player that still works , if i can locate it i think that will put it inside the base with a small speaker, with that sound running in loop.
Another week, more work, and another part of the Pandora is done. I've added the pin masts, and based on the actual Pandora I decided to add two pieces of grey string in order to replicate the chain attached to the pin masts in the game. For the first piece of string I used a small needle to create a hole to pass the string, for the second I tied the string to every pin mast with a knot. In order to make this work, I had to embed the pin masts with cyanoacrylate. The pin masts where attached to the hull using UHU super glue. I'm also planing some more changes to the original model, so in order to comply with the rules, I will release an extra page with my changes.
PS Thanks Gearz for the authorization.
Old 05-20-2008, 04:08 PM   #22 (permalink)
Tars
Default
Woooow! That's absolutely terrific. There more I look the more I feel I have to continue my own Pandora... arg!
__________________
www.planetstarfreak.de
Tars is offline   Reply With Quote
Old 06-02-2008, 07:37 AM   #23 (permalink)
xadow
Junior Member
Default
It took more time than I wanted, but the Pandora is done
Before the final pics, here some pics of the assembly of the guns, engines and engine supports.
For the barrels I decided to use a piece of wire, instead of the rolled paper version. Why? Simply because it was too small for my big fingers . Anyway they have the same size as the paper versions and roughly the same color.
Old 06-02-2008, 07:46 AM   #24 (permalink)
xadow
Junior Member
Default
Now for the engines. I created a new prop to be printed in transparency, and carved the spinners from a toothpick, as once again the paper version was too small for me, I painted every spinner and made sure they looked similar to the paper version.
I also created a thicker version of the engine supports, so that I could cut them from thick card.
In order to comply with the rules, and also after approval from Gearz (many thanks ) I give you the extra sheets, so that you can achieve the same look as I did http://www.xadow.info/extraparts.jpg
Old 06-02-2008, 07:53 AM   #25 (permalink)
xadow
Junior Member
Default
Finally added the engine supports and the engines.
And here it is the final pics.
I never had so much fun with a model before, the parts fit perfectly, and the outcome, at least for me, is breathtaking.
Many thanks to Gearz who created this magnificent model (and many others).
Check is work at:Sci Fi & PC Game paper card models
Old 06-02-2008, 09:51 AM   #26 (permalink)
Tars
Default
Wow! That looks even better than the original in the game! Congratulations!!
I especially like the transparent propeller discs!!
__________________
Old 06-08-2008, 12:10 AM   #27 (permalink)
Gearz
Gearz's Avatar
Default
Woohooo....Most excellent build xadow !!
That's exactly how I pictured her when I started developing the model. Your improved parts look Brilliant. + Those transparencies for the blade disk's are certainly the ticket for airships! I'm just looking at the few crumpled hull sections I'd test built, and all those small details may have been a pain to build but they make a BIG difference.
Thanks for permission to include your pics with the kit, I'll nip off now and fix it up..
I'll be back..
__________________
SF Models
Old 06-08-2008, 01:28 AM   #28 (permalink)
Gearz
Gearz's Avatar
Default
xadow ~ I've added your pics to the Pandora kit + added a note and link to the additional parts at my site. If you'd like any changes give me a 'hoy' and I'll fix it up.. * I'd guess most developers would agree that certain models can be like a ' message in a bottle' so Its a real pleasure to see one.. umm.. 'washed up on a beach' as it were.
Excellent build and dev work xadow..
__________________
SF Models
Old 06-09-2008, 06:47 AM   #29 (permalink)
xadow
Junior Member
Default
Thanks Gearz. I never had this much fun with a model before
I hoping that, in a nearby future, i will be able to build a larger version, i only need to find a place to put it
Old 06-09-2008, 08:29 AM   #30 (permalink)
Hot4Darmat
Hot4Darmat's Avatar
Default
Spectacular! Great build. Great model. Great photos.
__________________
___________________________________
Free Independence War Paper Models!
http://www.iwarpapermodels.org/content/index.htm
Hot4Darmat is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Best free model ever? Fluke69 Internet Finds 49 09-09-2007 10:54 PM
Free Model #2 silverw Current Competitions 70 03-03-2007 02:28 AM
Free Model #2 Roxxii Architecture Models 5 02-07-2007 01:42 AM
model for free zaqx Aircraft and Aviation 9 01-23-2007 05:59 AM
Not a free model but.... Kaz Internet Finds 0 11-19-2006 05:34 AM
Search Engine Friendly URLs by vBSEO 3.0.0 ©2007, Crawlability, Inc.
