#16 (permalink) |
Wow, I had no idea just how unreliable (over the long term) those little rail joiners would be. OK...I guess I'll be soldering everything together and that should help both the initial DC and the later DCC operations when I convert over. Since I've amassed quite a number of diesels, it's too costly to convert all of them to DCC right away, so I'll convert them to DCC slowly and be running a straight DC operation until I get enough decoder-equipt diesels. I just want to make sure I don't hamstring my own plan by not incorporating a major consideration for DCC...like track soldering the joints and feeder wires. Thanks again for the input.
__________________
Flying the Herc to pay for the trains! |
#17 (permalink) |
Technically, dcc should not be anymore fussy about electrical connections than dc; but it is. If you get a poor connection in dc, and flywheels in your locomotive enable it to get past the bad spot, it will continue on with no problem. If you have a bad spot on a dcc layout, it may require you to reaquire the locomotive to have it respond to your throttle. The biggest problem is shorts. A small short in a turnout for instance, that just causes a little spark as the locomotive runs through it, will shut down a dcc system.
#18 (permalink) |
When it comes to joining the track and weathering it, here's some tricks of the trade that I use.
Cutting Rail Joiners Rail joiners are too long, so cut them so that you only are using ½ to 2/3 of the joiner. Simply slide the rail joiner onto a piece of scrap rail, take an Atlas Snap Saw and saw off the excess part of the rail joiner. After you have sawed off the excess rail joiner, dress up the cut with a small file. Push the scrap rail through the cut to push out the burrs and file off the burrs. It may take a bit of extra care to slide the rail joiner onto the rail but it is well worth the effort. You can easily make a "tool" for holding the rail joiners. Take a small piece of wood about 1"x 1" square and 4" - 5" long. Drill a 1/8" hole about 2" into one end of the piece of wood. Stuff a bit of epoxy glue into the hole and push a piece of scrap rail into the hole so that it hits the bottom of the hole. You should have about 3" sticking out of the piece of wood. Or snip the rail off until you are comfortable with your "rail joiner holder" tool. Dress the ends of the rail with a file so that a rail joiner easily slides off the end of the tool. Dress (File) the Ends of Every Piece of rail Rail, whether Snap Track, Flex Track, or single pieces, has a "burr" on each end of the rail. This burr is created when the rail is cut into pieces - even when you use those rail nippers. Before you install the rail, "dress" (file) the ends of the rail at the web (bottom) and the sides. All it takes is a couple of swipes with a flat file. Don't push the file. Simply draw the file back towards you. This gets rid of the burrs and makes installation of the rail joiner very easy. Similarly, whenever you cut a piece of rail, whether with a razor or snap saw, or with rail nippers, dress the ends of the rail. Solder all joints Mechanical connections don't conduct electricity very well. It's usually a good idea to solder those rail joiners. All you need is a 20 - 40 watt soldering iron, some rosin core (electrical) solder, and some flux. Position your track in place with the rail joiner midway between the two pieces of rail. Apply a bit of flux. Make sure your soldering iron is well heated. Wipe the tip of the soldering iron a a wet sponge or a wet piece of cloth to remove the oxide that is created when you heat a soldering iron. Apply a touch of solder to the iron and shake it off with a quick flick of the wrist. Apply the soldering iron to the outside edge of the rail. Quickly touch the solder to the rail right next to the iron and remove the solder. Move the soldering iron down the length of the rail joiner. Don't linger very long as you can quickly melt the plastic ties. No longer than 2 seconds (slowly count one thousand, two thousand). Painting Rails There are several ways to weather the rails. The easiest is with an orange and black magic marker. Simply apply the orange marker to the side of each rail first. Let it dry. It may require several coats. Then apply the black magic marker. At least this will get rid of that bright shine on the rails. Don't apply the magic marker to the top of the rails! After you have your track in place, clean the top and inside flange of the rails with a bright boy or sanding sponge. The ultimate way is to paint the rails. However, it does require a bit of extra work but the results are worth the effort. I do this using a 2-step process. First, apply some light sewing machine oil to the top and inside flange of the rails. Or, apply some masking tape cut into 1/8" strips to the top and inside flange of the rails. On your turnouts, apply masking tape to the top of the points or stuff some kleenex into the open side of the points If your rail is fastened to your layout, mask off the parts of the layout on each side of the track. The first coat of paint is a red oxide primer in the spray can, (Tremclad for example) that is generously sprayed on the rails and the ties - the inside edges, the outside edges, the top of the ties, the sides of the ties. Don't over-do the spray! Hold the spray can about 18" from the track. The red oxide is really bright so we now need to tone it down. Before the red oxide dries, over-spray the track with a light coat of flat black. The idea here is to add "highlights" to the red oxide so that we have a mix of "rust" (the red oxide" and the creosite, oil, dirt, etc). We want enough of the red oxide showing through, however, so that we know it is rusted rail. Let the paint dry. The next part does require a bit of work but the effort is well worth it. If you've masked the top and inside flange of the rail, your work is relatively easy. If you didn't mask the rail, you will require a bit of elbow grease. The paint on the top and inside edge of the rail needs to be scraped off. I do this using a variety of tools ranging all the way from a 1/8" square steel bar, an X-Acto knife and a bright boy - anything that will scrape off the paint. I even use paint remover. After all of the paint on the top of the rail and the inside flange has been scraped off, I polish up the rail with a bright boy or sanding sponge. Carefully inspect the rails to ensure that all of the paint has been removed. And voila, you have weathered track! The weathered track, combined with the shortened rail joiners and some ballast will give you some really nice-looking trackwork. For an idea of what it all looks like, visit this page on my website. Laying the Roadbed and Track - Page 1 Bob M. Last edited by railwaybob; 05-14-2008 at 09:35 AM. |
#19 (permalink) |
The top photo was taken after the track was weathered and fastened to the module deck. The bottom photo is after the scenery was added and the track ballasted. You may notice that the bottom photo is looking down the track into the siding on the right in the top photo.
You have to look real hard to find those rail joiners, even at the ends of the turnouts! The impact of weathering of the track is quite obvious, eh? Bob M. |
#20 (permalink) |
Wow Bob, thanks for a great tutorial! My compliments on taking the time to write all that out. I never thought of shortening the rail joiners and I think I might try that. (BTW...nice website! Lots of interesting info.)
Soldering the track sections I can see by the popular opinion is a must and another idea I'll incorporate. I've already sprayed some of the track lightly, and some not so lightly, so I'll go back and replace problematic track sections that may not conduct as well as others. Everyone's ideas have been great and I'm guessing they're gleaned from problems experienced in the past. Thanks again for some great info! When I get something built worthy of a picture, I'll post it here since you've all had a hand in its creation.
__________________
Flying the Herc to pay for the trains! Last edited by Herc Driver; 05-14-2008 at 10:09 PM. |
#21 (permalink) |
Herc, a trick to use to keep from melting ties when first learning to solder is to cut out the little "spacers" that are between the ties on the bottom of the track. The idea is to be able to slide the ties near the end of the track together to get about 3 inches or so of bare rail on both sides of where you solder the joiners into place. Next get 2 wash cloths or rags made of material that will absorb lots of water. Lay out the track on your work bench, connect the two rail sections with your rail joiners, and slide the ties back from the joiners. Take your 2 rags that have been soaking in a bowl of water, wring them out so that they are wet but not dripping, and lay them over the top of the sections of rail and tie. Leave about 2 inches or so of the rail on each side of the rail joiners sticking out so they don't get wet. You now have a most effective heat sink that will allow you to solder the rail joiners to the ends of the rail, but you can't get the rail that is over the ties hot enough to melt the ties until you have added enough heat to boil all of the water out of the rags to completely dry!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Cleaning spray painted track | Herc Driver | Technical Q & A | 12 | 06-24-2008 11:45 PM |
| electrical problems | Collyn | General Talk | 9 | 04-29-2007 04:07 PM |
| Spray painting a paper model | andrew ferguson | Tips and Techniques | 15 | 02-05-2007 11:13 PM |
| Electrical problems | 507wayne | HO Scale Model Trains | 5 | 07-28-2005 11:54 AM |
| Painting Track | Jim Cullen | N / Z Scale Model Trains | 13 | 06-16-2003 12:21 AM |
